Page 3 of 3 1 2 3
Re: additional cooling [Re: burdar] #2282426
04/04/17 08:20 PM
04/04/17 08:20 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Originally Posted By burdar
Yah, "high flow" is their description. It's high flow compared to their under drive pulley that usually comes in the kit. I was just trying to give him an option since all of his other pulleys are aluminum. If the problem ends up being the fan, maybe the 6.4" pulley would work?
Ya, Thanks for that info. If the weather ever warms up around here, I will give a report on the 7.25 OEM steel crank pulley that I have on there right now. I would like to stick with all aluminum pulleys, so if the 7.25 works real good, I might try going to the 6.4 aluminum pulley you mentioned.
As a side note, I actually had to trim about 1/32" off the O.D. of the steel pulley I am using to keep it from hitting my existing water pump pulley. I should know pretty quick if the water pump bearing ever starts to fail. eek
Fastest 300
Re: additional cooling [Re: Crizila] #2283082
04/05/17 10:50 PM
04/05/17 10:50 PM
minnesota
dondon Offline
dondon  Offline
minnesota
My 34 ply ran hot. What I did in steps, was remove 340 pulleys and put on 360 pulleys, relocate trany cooler from bottom tank, to under the running board, and the thing that helped the most was putting on a 7 blade engine driven fan, not a clutch fan. That alone took 15 degrees out of the probelm. Also did that on another car and it did the same. Brass radiators will remove more heat than an alumunim radiators,
Re: additional cooling [Re: Crizila] #2312165
05/27/17 11:19 PM
05/27/17 11:19 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Just a Quick up date on this thread. Did the Route 66 fun run a few weeks ago and got to drive in just about all weather conditions over the 3 days we were gone. The big test was the first day when the temp ran in to the mid 90's. We were pulling a small trailer to add to the situation. Hottest it got pulling up a long hill at 92 degrees ambient with the trailer was 220. Level surface at the same temp it hung around 205. The little air direction scoop I put at the bottom of the grill seemed to really help at speed. Ran a little cooler at 65mph than 55mph. This, again, was with no stat in the system. We ran in to some 60 degree temps on the way home and the temp dropped below 180 at times. Obviously too cool. So, per many's suggestion, I put a 180 degree high flow stat in. I will be trying it that way in a week or two. Thanks all again for your many suggestions.
Fastest 300
Re: additional cooling [Re: Crizila] #2312293
05/28/17 10:13 AM
05/28/17 10:13 AM
moparx Online content
moparx  Online Content
glad it's working out for you ! up [i just love that color with the sun on it !]
beer
Re: additional cooling [Re: moparx] #2312314
05/28/17 11:13 AM
05/28/17 11:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: additional cooling [Re: Crizila] #2312382
05/28/17 01:27 PM
05/28/17 01:27 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
Not sure if this matters, or has been mentioned, but some marine inboards use a 140 degree stat. Slows down the coolant but also opens sooner? confused
Re: additional cooling [Re: Crizila] #2330501
07/03/17 02:26 AM
07/03/17 02:26 AM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
John, I have a double pass Ron Davis radiator in my Hemi Model A and have no problems in the AZ heat.
Page 3 of 3 1 2 3
