Freeze plugs #2326887
06/26/17 11:56 AM
06/26/17 11:56 AM
Great Neck,LI,new york
hemi-itis Offline OP
Which freeze plugs do you guys prefer,steel or brass.I need to order a set and had 2nd thoughts.I have used brass with good luck shruggy
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Freeze plugs [Re: hemi-itis] #2326889
06/26/17 12:01 PM
06/26/17 12:01 PM
an8sec70cuda Offline
Brass.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Freeze plugs [Re: hemi-itis] #2326896
06/26/17 12:15 PM
06/26/17 12:15 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Brass. No rust
Rich H.
Esse Quam Videri
Re: Freeze plugs [Re: hemi-itis] #2326919
06/26/17 12:59 PM
06/26/17 12:59 PM
Just as I thought,now if Todd would answer the phone,,,,,,,,,,,,
Re: Freeze plugs [Re: hemi-itis] #2326929
06/26/17 01:20 PM
06/26/17 01:20 PM
Todd is slackin,took him 18 minutes to call me,,,,,,,LMOL!!
Thanks http://www.mopartsracing.com/tmc/ for being one of the best vendors for MOPAR addics like,,,,,,,,us!
Re: Freeze plugs [Re: hemi-itis] #2326973
06/26/17 02:17 PM
06/26/17 02:17 PM
They both work well installed correctly up
If it is a race only motor or some other motor like in a boat with no antifreeze brass only up
Re: Freeze plugs [Re: hemi-itis] #2326989
06/26/17 03:01 PM
06/26/17 03:01 PM
I had a steelie rot out on me!
Re: Freeze plugs [Re: hemi-itis] #2327059
06/26/17 05:57 PM
06/26/17 05:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Gimme gimme gimme, has to better than mine.
Re: Freeze plugs [Re: hemi-itis] #2327074
06/26/17 06:38 PM
06/26/17 06:38 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I use the brass deep cup plugs.
Re: Freeze plugs [Re: rickraw] #2327152
06/26/17 09:20 PM
06/26/17 09:20 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Brass with a little smear of Permatex form-a gasket (full cure version) wiped in the hole first. Had bad luck with ones installed dry weeping when it gets really cold outside (below freezing for weeks). On a garaged race car that shouldn't be an issue.
Re: Freeze plugs [Re: hemi-itis] #2327180
06/26/17 10:15 PM
06/26/17 10:15 PM
jersey
Spaceman Spiff Offline
jersey
Only a little over 2 weeks till carlisle.....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Freeze plugs [Re: Neil] #2327183
06/26/17 10:19 PM
06/26/17 10:19 PM
I think the steel grabs a bit tighter tho many people have used brass with no issues and the wide steel ones are slightly harder to come by. I would use Permatex #1 cement in the toothpaste like tube & drive em in with a socket on the perimeter rim as opposed to deep down inside.
Re: Freeze plugs [Re: RapidRobert] #2327222
06/26/17 10:56 PM
06/26/17 10:56 PM
IN
ahy Offline
ahy  Offline
IN
I used brass first go around and no issues. On freshen the builder recommended and installed steel with the idea they have more strength and less chance of popping out.
I run good anti-freeze so either should last a really long time.
Re: Freeze plugs [Re: hemi-itis] #2327320
06/27/17 01:10 AM
06/27/17 01:10 AM
I had a steel one blow out during a pass,it was an interesting ridesmoke
Todd had the Milodon brass set in stock and mailed yesterday.Should have the shortblock done in a few days. Paint is dry!
Re: Freeze plugs [Re: hemi-itis] #2327409
06/27/17 08:36 AM
06/27/17 08:36 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Dorman used to make some really slick copper ones with an acorn nut in the middle. You would tighten the nut to expand the plug.
[image][/image]
Re: Freeze plugs [Re: hemi-itis] #2327413
06/27/17 09:29 AM
06/27/17 09:29 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Brass all the way...won't rust out
Re: Freeze plugs [Re: sgcuda] #2327477
06/27/17 12:15 PM
06/27/17 12:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
They still do and the really come in handy at times.
http://www.dormanproducts.com/c-353-expansion-plugs-quick-seal-copper.aspx
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Freeze plugs [Re: hemi-itis] #2327499
06/27/17 01:21 PM
06/27/17 01:21 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I want to seal the cam plug so I think I will use some high tack red,should work?
Re: Freeze plugs [Re: Clanton] #2327519
06/27/17 02:29 PM
06/27/17 02:29 PM
PA.
"Little"John
"Little"John
PA.
One of the members turned me on to Indian Head gasket shellac compound so I bought two bottles from Advance Auto and really like it
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Freeze plugs [Re: pittsburghracer] #2327521
06/27/17 02:30 PM
06/27/17 02:30 PM
PA.
"Little"John
"Little"John
PA.
I take that back as it says Napa on the bottle and is made by Permatex.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
