Fuel Gauge, '92 Dodge 150
#2326840
06/26/17 10:46 AM
06/26/17 10:46 AM
Posts: 1,286 IN
GTX4spd
IN
Picked up a decent '92 150 yesterday, one of the few mechanical issues it has is the fuel gauge not working. A new fuel pump was included with it, the previous owner was of the opinion that was where the problem lay. Is the sender for the gauge part of the pump, & is that the probable issue?
Since the pump in it currently is working fine I don't want to change it needlessly, nor waste my time chasing the incorrect fix.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin
www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: Fuel Gauge, '92 Dodge 150
[Re: GTX4spd]
#2326869
06/26/17 11:24 AM
06/26/17 11:24 AM
RapidRobert
elec or mech pump? my 85 ramcharger (mech) is inop (reads empty). I think the sender is in the top of the tank & I sure ain't gonna drop the tank to fix it (its a junk DD) but I might ohm the wires either back there or behind the dr kick panel to see if it is a sender issue or a prob further up front. here's a BTT for ya.
[Re: GTX4spd]
#2326888
06/26/17 11:59 AM
06/26/17 11:59 AM
Posts: 1,286 IN
GTX4spd
IN
Thanks. The pump is electric, on this truck I wouldn't need to drop the tank, just raise the bed a bit. Had to replace the pump on my '01 several years ago & raising the bed is relatively simple. Not an option with your Ramcharger.
[Re: GTX4spd]
#2326959
06/26/17 01:56 PM
06/26/17 01:56 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
If it's just a fuel pump then no the sender is not part of it. If it's the complete assembly then yes the sender and float should be included.
[Re: GTX4spd]
#2326964
06/26/17 02:03 PM
06/26/17 02:03 PM
Posts: 1,286 IN
GTX4spd
IN
Okay, sounds as though that should be it, it is the complete canister assembly. Not too difficult, better than tracking down faulty wiring if that is where the problem lies.
Thanks!
