2014 Ram-6.7 Cummins- oil and filter recommendations #2325143
06/22/17 11:00 AM
06/22/17 11:00 AM
NH
N
NHCharger Offline OP
N
NH
I google searched this but as usual came up with a wide variety of answers.
So what are you guys using for oil and filter, and how long are you going between oil changes??
There also seems to be a debate about filling the new oil filter up before installing it.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: 2014 Ram-6.7 Cummins- oil and filter recommendations [Re: NHCharger] #2325166
06/22/17 12:15 PM
06/22/17 12:15 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Fleetguard Stratapore
Filters linky - click here
I think the filling vs. non filling is an old issue, if I remember right some people were pretty sloppy about getting foil debris in the engine. I always fill mine 2ยข
All the big name Diesel oils are good. I shy away from Rotella because of the smell. Just pick the grade for your operating temperatures.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 2014 Ram-6.7 Cummins- oil and filter recommendations [Re: NHCharger] #2326081
06/24/17 12:44 PM
06/24/17 12:44 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Fleetguard, Mopar, or Cummins filter.... one in the same. When you see how your oil filter fits on that 14 you won't fill it prior to install. Even on my 01 I've never filled it. Interval.... follow the minder your truck is equipped with and it will take you anywhere from 10-14K interval. I'd say anywhere from 7-9 k would be fine if your not comfy with extending it. We run Rotella 15-40 in the reels at work.
