Page 3 of 3 1 2 3
Re: Dremel bit for aluminum? [Re: mopower440] #2324964
06/21/17 10:57 PM
06/21/17 10:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted By mopower440
what about this set?
burrs
I hate to see people waste their money or spend their money but a 1/8 inch dremel tool is not the right tool for this job.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dremel bit for aluminum? [Re: mopower440] #2324965
06/21/17 11:00 PM
06/21/17 11:00 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Those are wood carving bits.
Re: Dremel bit for aluminum? [Re: GomangoCuda] #2324968
06/21/17 11:03 PM
06/21/17 11:03 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
I thought they looked like the ones posted above..back to the drawing board..
Re: Dremel bit for aluminum? [Re: GomangoCuda] #2324980
06/21/17 11:21 PM
06/21/17 11:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The ad claims......
Usage: for materials such as wood; plastic; soft metal as aluminum...
They would probably last long enough to open up that w/p housing.
Re: Dremel bit for aluminum? [Re: pittsburghracer] #2325139
06/22/17 10:51 AM
06/22/17 10:51 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Originally Posted By pittsburghracer
Originally Posted By DaytonaTurbo
pitts, are you using any particular brand of burr? I have found the cross cut ones to be too slow for anything but finish work. Maybe the cheapo ones I have been using are just crap?
I use the heck out of this one from Summit. Its not the best place to get burrs but I usually place 2-3 orders a week so its convenient. I keep a plastic dish with a mixture of WD40 and transmission fluid and dip often. And I know its listed for cast iron but trust me keep it dipped and you will love it. Go slow because if you go like a wildman it will bend. They also offer a shorter one that is easier to handle.
https://www.summitracing.com/parts/sum-900643
I'm going to give that a try again on my next aluminum job. I think my problem is I'm not dipping enough and letting the bit run dry.
Re: Dremel bit for aluminum? [Re: mopower440] #2325654
06/23/17 10:54 AM
06/23/17 10:54 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
If you don't do head work often, use a Foredom grinder. Speed control built and uses 1/8 and 1/4 shank bits. It gives you cushion from screwing up a job with better control.Faster learning curve with fewer problems. Dental labs have been using them for years.
Re: Dremel bit for aluminum? [Re: A/MP] #2325773
06/23/17 03:19 PM
06/23/17 03:19 PM
PA.
"Little"John
"Little"John
PA.
I do 100% of my head and intake porting with the higher HP Foredom grinders and the biggest (heavy duty) hand piece. Kinda expensive even used for the guy who isn't going to do this very often. I love mine and will never use anything else again
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dremel bit for aluminum? [Re: pittsburghracer] #2325803
06/23/17 04:34 PM
06/23/17 04:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
As for bits,only thing I ever used,don't clog and don't dull,were almost $100 when I bought them,don't know it they are still available.
Re: Dremel bit for aluminum? [Re: mopower440] #2325906
06/23/17 09:13 PM
06/23/17 09:13 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
That's a nice set there Bill...Seems ingersol rand doesn't make much in the US anymore...
I have a feeling a small dremel tool will cause nothing but grief for the material that's needed to be removed from the water pump housing.. As suggested a die grinder size bit will save you some aggravation... Harbor freight has cheapie air die grinders for around 10 bucks..
Here's a pic showing what happens to a normal single flute metal bit in short order when trying to cut aluminum..The two bits on the right side are aluminum cutting bits..There's a stick wax{made by castrol} that you can use to keep the aluminum cutting tools from clogging up I'll include a pic of it..
Re: Dremel bit for aluminum? [Re: mopower440] #2325957
06/23/17 11:51 PM
06/23/17 11:51 PM
middle Tennessee
middle Tennessee
I got a bit from lowes and hogged out the housing. I think it will work just fine now. The lower left port is the culprit that is too small and i opened it up pretty good. Equal to the other side now..
Re: Dremel bit for aluminum? [Re: mopower440] #2326059
06/24/17 11:43 AM
06/24/17 11:43 AM
moparx Online content
moparx  Online Content
good to hear positive results ! how much did you have to remove, and how deep did you have to go before you got the housing to your liking ? any pics ?
beer
Re: Dremel bit for aluminum? [Re: mopower440] #2326352
06/25/17 11:13 AM
06/25/17 11:13 AM
middle Tennessee
middle Tennessee
Hard to say how much, it didnt take long with that bit i used, the shavings accumulated quick..
Page 3 of 3 1 2 3
