Re: Proper 2017 Oil for flat tappet classic mopar cams
[Re: Prochargedmopar]
#2324911
06/21/17 09:01 PM
06/21/17 09:01 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
As others have stated, the cam/springs combo is important. But, if you're just looking for VERY accurate data concerning the ZDDP of common oils, this thread is a good place to start. The data is about 3 or 4 years old, but I doubt that the concentrations have changed much.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
#2324947
06/21/17 10:20 PM
06/21/17 10:20 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
I have factory pattern 383 HP and I just use whatever, usually Super Tech 15w-40. Sometimes I try straight 30, 10w30, 10w-40, it doesn't seem to matter that much. However, the original valve train is nothing extreme.
If I had the current aftermarket steep cam and high spring pressure, I would be a lot more cautious.
68 Roadrunner. 383 4-spd. Beat up.
#2325086
06/22/17 04:39 AM
06/22/17 04:39 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Myself I have used Valvoline oil since I started working on cars in the early 70's. When the VR1 racing oil came out I started using it and have used it for years. I have never built a roller cam eng for myself as all my engines have been and still are flat tappets. And knock on wood I have never had a cam wipe a lobe. Course I do make sure everything is working right like making sure all the lifters are rotating and so on. Right now I am running the non synthetic Valvoline VR1 20W-50 racing oil which I usually run in all my engines. I have always had great results with the Valvoline oil so stick with it since it has worked great for me all these years. Ron
