55 Plymouth Savoy M body front suspension swap
#2324170
06/20/17 01:14 PM
06/20/17 01:14 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Anyone done a FMJ swap to one of these cars? Have a line on both and it looks like track width wise I should be good but may need to change front rails. What others done and where are some links? Roadster shop has done one but they left the rear rails stock width with pizza cutters on the back. I plan to minitub this one and back half it to.
Mopar to the bone!!!
Re: 55 Plymouth Savoy M body front suspension swap
[Re: 72Swinger]
#2327124
06/26/17 08:23 PM
06/26/17 08:23 PM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
I looked at a 56 Dodge for sale locally that had a Fifth Ave clip in it, the front frame rails were spliced in. Well done job and everything fit, it sat low and it was hard to tell it was altered at first look!!! Track width was good too.....
CrAzYMoPaRGuY
[Re: 72Swinger]
#2327954
06/28/17 10:28 AM
06/28/17 10:28 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure why someone would want to take a rear steer setup and totally waste the geometry by putting a front steer rack in it.
Be smarter to use a rear steer rack.
[Re: Old Ray]
#2328000
06/28/17 11:48 AM
06/28/17 11:48 AM
Posts: 237 British Columbia, Canada
Old Ray
Using a Dakota with rack and pinion steering there is no steering box! Seems to be some misunderstanding here.To clarify; Using a Dakota (sub-frame) with rack and pinion steering there is no steering box!
[Re: 72Swinger]
#2328235
06/28/17 08:10 PM
06/28/17 08:10 PM
Supercuda
About to go away
About to go away
up yours
I put over 200k miles on my 87 Diplomat with no geometry issues. Can't blame the suspension for a bad install.
[Re: dogdays]
#2328818
06/29/17 08:48 PM
06/29/17 08:48 PM
CrAzYMoPaRGuY
Canada
The transverse torsion bar front end has a big problem with suspension geometry.
I have a friend who bought a mid '50s ford pickup with one, and it seems to have been installed wrong. The truck was actually dangerous to drive. It required a lot of dedication from a front end shop to get it so it felt safe on the highway.
The Dakota front end is a much better design, technically. Shoot, the '55 front end is probably better. As disk brake kits and rebuild parts are available, why swap at all? Even dropped spindles can be found.
R. Your friend might have problems but the FMJ front ends don't. I've driven lots of them.
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2328916
06/29/17 11:57 PM
06/29/17 11:57 PM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
R. Your friend might have problems but the FMJ front ends don't. I've driven lots of them. I agree, I have installed 4 of the FMJ crossmembers myself and all worked very well, can't blame the parts for a poor install job. That said, I do like the Dakota much better. Gene
[Re: poorboy]
#2329293
06/30/17 07:55 PM
06/30/17 07:55 PM
CrAzYMoPaRGuY
Canada
R. Your friend might have problems but the FMJ front ends don't. I've driven lots of them. I agree, I have installed 4 of the FMJ crossmembers myself and all worked very well, can't blame the parts for a poor install job. That said, I do like the Dakota much better. Gene I'm trying a Dakota out for the first time. I've got my 60 D100 ready for some newness.....
CrAzYMoPaRGuY
[Re: Twostick]
#2334431
07/10/17 12:12 AM
07/10/17 12:12 AM
Supercuda
About to go away
About to go away
up yours
The FMJ has geometry issues from a performance driving standpoint ie road racing etc. Daily driving chores not so much.
Kevin That would be a different forum and thousands of cop cars tell me the FMJ suspension is just fine for 99% of what anyone will do with it. If you are the 1% then I doubt any 100% stock setup will suffice.
