Re: Dremel bit for aluminum?
[Re: mopower440]
#2324964
06/21/17 10:57 PM
06/21/17 10:57 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
what about this set? burrs I hate to see people waste their money or spend their money but a 1/8 inch dremel tool is not the right tool for this job.
[Re: GomangoCuda]
#2324980
06/21/17 11:21 PM
06/21/17 11:21 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Those are wood carving bits. The ad claims...... Usage: for materials such as wood; plastic; soft metal as aluminum... They would probably last long enough to open up that w/p housing.
[Re: pittsburghracer]
#2325139
06/22/17 10:51 AM
06/22/17 10:51 AM
DaytonaTurbo
Manitoba, Canada
pitts, are you using any particular brand of burr? I have found the cross cut ones to be too slow for anything but finish work. Maybe the cheapo ones I have been using are just crap? I use the heck out of this one from Summit. Its not the best place to get burrs but I usually place 2-3 orders a week so its convenient. I keep a plastic dish with a mixture of WD40 and transmission fluid and dip often. And I know its listed for cast iron but trust me keep it dipped and you will love it. Go slow because if you go like a wildman it will bend. They also offer a shorter one that is easier to handle. https://www.summitracing.com/parts/sum-900643 I'm going to give that a try again on my next aluminum job. I think my problem is I'm not dipping enough and letting the bit run dry.
