Proper 2017 Oil for flat tappet classic mopar cams
#2323252
06/18/17 08:21 PM
06/18/17 08:21 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
I just watched a youtube video saying ALL new off the shelf oil will wipe the lobes off our classic car camshafts.
Its been 12-14 yrs since Ive had mine on the road last and it said late 90's the oil companies lowered zinc/phosphorous amounts.
What is truth and what oil do I use.
Historically I've always used mobil 1.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
Re: Proper 2017 Oil for flat rappet cams
[Re: Prochargedmopar]
#2323263
06/18/17 08:36 PM
06/18/17 08:36 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I use Valvoline VR-1 with my .650 SFT. Pulled the valley tray to have a look and the lobes look perfect. Doesn't break the bank and its available everywhere.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
#2323311
06/18/17 10:38 PM
06/18/17 10:38 PM
Prochargedmopar
Granbury TX
So i take it that it was legit?
The guy in the vid recommended Joe gibbs oil (now driven) but said had no affiliation with them. $10 a Qt. Ouch.
Also said all the major brand oil claims were bogus and didnt have enough zinc.
Where you guys buying valvoline?
[Re: formula_s]
#2323326
06/18/17 10:58 PM
06/18/17 10:58 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
I believe Autozone has it but only in 50 weight. Can't imagine who has use for it.
#2323332
06/18/17 11:08 PM
06/18/17 11:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Really depends on the cam being run. My stock 2bbl cam in the 273 runs just fine on whatever 10w30 is on sale.
[Re: BDW]
#2323546
06/19/17 12:10 PM
06/19/17 12:10 PM
RapidRobert
On a side note I hear www.bobistheoilguy.com is a good read. As said I would go with one of the brands that get touted on here regularly, brad Penn/valvoline VR1 & several others. the search function would have something.
#2323646
06/19/17 03:38 PM
06/19/17 03:38 PM
71yelladustr
Missouri U.S.A.
Howard's also has a direct lube EDM lifter that works well for added protection against worn lobes.
[Re: Supercuda]
#2323866
06/19/17 10:42 PM
06/19/17 10:42 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Really depends on the cam being run. Exactly. It's about Spring Pressure. The anti-wear packages in many current grades are as good or better than what was normally sold in 1968 or 71. However if your running a cam with fast ramp and high spring pressures then yes you probably want to be sure the oil has the a really good package for the sliding follower action. If you really want to know about oil selection for older engines, then check out Richard Widman's paper. He even sent out a sample of classic motor oil for analysis. http://www.widman.biz/Corvair/English/Links/Oil.html
[Re: Porter67]
#2323904
06/19/17 11:29 PM
06/19/17 11:29 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Alot of links but little hands on input here....hmmm. I have used Brad Penn and VR1 with great results, I guess that would qualify as hands on results Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#2323911
06/19/17 11:45 PM
06/19/17 11:45 PM
Supercuda
About to go away
About to go away
up yours
hands on means anecdotal. Unless you got analysis results it's useless.
At least the link has the analysis.
