Page 3 of 4 1 2 3 4
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2323034
06/18/17 01:15 PM
06/18/17 01:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By TimS
....Also all isn't good when the bars are set to the springs. That just makes the car bearable to drive. It still has some shake just not violent shake. Shook with my worn out stock springs too....
Was this before or after all the other drivetrain work? Just trying to establish a time line of what you did and the effects of what you did.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2323066
06/18/17 02:23 PM
06/18/17 02:23 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Using wheel chocks or If handbrake works well enough to hold car well, engage it tightly and with transmission in low gear, give it some gas and let out the clutch. Have an assistant view rear springs while doing so. Any shudder or other observations of note in behavior of springs or driveline?
Would certainly be better to be on a drive on lift,,,,,looking for unusual engine and transmission lift or rock.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2323082
06/18/17 02:47 PM
06/18/17 02:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Reposting this as it may have slipped by,
Another thought I just had would be to check the air gap as the disc is being engaged with say a feeler gauge looking for irregularities. While this would not expose contaminated / irregular surfaces it might expose a bent disc, warped PP, or bent input shaft
This can easily be done by adjusting the length of the clutch rod.
Re: Bell housing to Crankshaft Concentricity Question. [Re: rowin4] #2323105
06/18/17 03:17 PM
06/18/17 03:17 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Originally Posted By rowin4
I didn't go back and read every post but early on you state that you got a new clutch set from Brewer. What did you tell him you were going to be using your car for? Did they sell you a Hi performance disc? such as a Kevlar one? Those will grab,not slip on take off and will cause the symptoms you have. Other than that , mounts, motor and transmission. They might look OK but if they have never been changed out there 50 years old. Shocks , the same , they may look good but don't last forever.
Yep this setup Wayne suggested. It just happens to be the same setup I used in my stock 383 4 speed Super Bee a few years ago. Same use, just street. Not one issue with that.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Bell housing to Crankshaft Concentricity Question. [Re: 6PakBee] #2323107
06/18/17 03:19 PM
06/18/17 03:19 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Was this before or after all the other drive train work? Just trying to establish a time line of what you did and the effects of what you did.
Adding the super stock springs is the last thing I did. I then stuck the traction bars on.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TJP] #2323113
06/18/17 03:23 PM
06/18/17 03:23 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
When I was going over the linkage looking for irregularities, I did adjust around on the rod just to see what would happen at various engagement points. It shook at all of them.
Re: Bell housing to Crankshaft Concentricity Question. [Re: Sxrxrnr] #2323114
06/18/17 03:24 PM
06/18/17 03:24 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Originally Posted By Sxrxrnr
Using wheel chicks or If handbrake works well enough to hold car well, engage it tightly and with transmission in low gear, give it some gas and let out the clutch. Have an assistant view rear springs while doing so. Any shudder or other observations of note in behavior of springs or driveline?
I need to do this test again. I've done it once and I'm pretty sure I saw no shake with that. That's what pointed me to the back end and changing the springs.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2323124
06/18/17 03:41 PM
06/18/17 03:41 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Could clutch disc when released, not move freely on transmission main spline. I had always checked for this many years ago when was still replacing clutches, did so before bolting pressure plate in place. More than once had found a problem,,,,and a couple of times with a disc not runing true when spun on a smooth bench top surface.
I will post this thought on the other thread of the day suggesting another clutch problem.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2323262
06/18/17 08:34 PM
06/18/17 08:34 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Just did another check of my LH motor mount. This car has power steering so it's not the easiest to see but I set the mercy brake on the car and popped the clutch a few times. Had someone watch the motor mount and even took a video. The rubber does separate and is cracked almost all the way across about 1/16th from the top of the mount. It's not all the way thru though cause the motor still does not raise up enough from left to right under torque for the air cleaner to tag the hood. It does indicate a questionable mount. Car does not shake or anything slip while the brake is set and popping the clutch to raise the motor.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2323645
06/19/17 03:37 PM
06/19/17 03:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I replaced the shocks all round and have the longer units in the rear to accommodate the super stock springs.
Did you check/reset the pinion angle when you put those springs in?
The fact that you said it went away , for the most part , with snubber bars up against the rear springs tells me it's a driveline issue. Pinion angle is the first thing to look at.
Where's Quicktree ?
Re: Bell housing to Crankshaft Concentricity Question. [Re: JohnRR] #2323832
06/19/17 09:26 PM
06/19/17 09:26 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Where's Quicktree ?
Yes I did experiment with the angle shims after putting the new springs in. I've looked at this pinion angle allot and tried different negative angles with no success in getting rid of the shake.
Another odd thing to me is that when I set the mercy brake and bump engage the clutch, I get no shake. That test led me to the rear thinking the motor, tranny clutch area was fine.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2324110
06/20/17 11:47 AM
06/20/17 11:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Where's Quicktree ?
How about an actual pinion angle reading ? Was negative actually the correct way to go ?
Re: Bell housing to Crankshaft Concentricity Question. [Re: JohnRR] #2324131
06/20/17 12:17 PM
06/20/17 12:17 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Where's Quicktree ?
Yes. Negative is where you want to be in relation to the tranny tail. My readings have been anywhere from -2.5 to -8, depending on what shims I had in place.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2325118
06/22/17 08:46 AM
06/22/17 08:46 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I see in the latest edition of Hemming's Muscle Machines there is a fella with a 69 Dart 383 4 speed car & 3.23 SG with the same problem that wrote in. His car is original also with the drive train rebuilt. Common theme it appears. He has also replaced the clutch twice. New flywheel and various parts as well.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2325186
06/22/17 12:53 PM
06/22/17 12:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have a 69 383 4 speed dart with the original sagging rear springs , I don't remember any issue with either a borg&beck 3 finger or the McLoed Borg&Beck/Long. The stock borg&beck did have a vibration issue in the engine itself but that was caused by the flywheel that was cut at an angle and was hot fully neutral because of it.
Re: Bell housing to Crankshaft Concentricity Question. [Re: JohnRR] #2325206
06/22/17 01:19 PM
06/22/17 01:19 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Where is Rhinodart in this discussion? No disrespect to anyone who has posted but if anyone knows about this kind of generic problem he should.
Re: Bell housing to Crankshaft Concentricity Question. [Re: 6PakBee] #2325270
06/22/17 03:20 PM
06/22/17 03:20 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I think Rhinodart lives in Illinois as well, not too far from me. Heck I would take the car to him if he didn't mind looking at it for me. I've tried so many things to this point that I'm wondering if it's something I've missed along the way. I've had lots of other eyes on this thing too but I wouldn't call the eyes real experienced on 4 speeds and their setup. I believe that's what this will take.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2325342
06/22/17 05:49 PM
06/22/17 05:49 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
We are all curious on this one, hopefully if cause is found that finding is posted.
All too often this important close out report does not happpen. Important for those who have posted their ideas,,,and for the next member to experience the same problem.
Re: Bell housing to Crankshaft Concentricity Question. [Re: Sxrxrnr] #2325351
06/22/17 06:09 PM
06/22/17 06:09 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Absolutely. Responding back with a post will be the first thing I do after figuring this issue out. 40 years of working on these things, mine and my friends cars, and I've never have had a problem I've worked on for so long.
Re: Bell housing to Crankshaft Concentricity Question. [Re: TimS] #2326027
06/24/17 09:02 AM
06/24/17 09:02 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I do plan to replace that motor mount but since it's not cracked all the way thru I don't believe it is the source of the shake.
Page 3 of 4 1 2 3 4
