My used Eagle heads...on the bench, as delivered.
#2313359
05/30/17 01:27 AM
05/30/17 01:27 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
First Gen 3 parts I've ever owned, tossed them up on a flow bench today. Untouched, completely stock, as far as I can tell. Testing on a 4.00" bore. Wow...
259 @ .400 267 @ .450 271 @ .500 286 @ .550 292 @ .600 298 @ .650 301 @ .700
The big surprise was the valve springs. Could these be stock??
126# closed at installed height 350# at .550 open Looks they are done at .585, but seems pretty stout for an OE spring.
Re: My used Eagle heads...on the bench, as delivered.
[Re: cudadoug]
#2313388
05/30/17 02:51 AM
05/30/17 02:51 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Your numbers are a little lower than what most of us get. Most of us have hit 300 by .5 and stays the same at .6
Ive went rounds before over the valve springs. When i tested them, the pressures were better than pac 1218s i think i had at the time.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: cudadoug]
#2313645
05/30/17 04:46 PM
05/30/17 04:46 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Seeing what the heads are capable of was one of the big reasons I jumped off the BB ship. IMO opinion they are the best engines to use in a NA 600-700hp pump gas application period.
Mopar to the bone!!!
[Re: cudadoug]
#2314509
06/01/17 11:29 AM
06/01/17 11:29 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
259 @ .400
done at .585 ...Coil bind or clearance ?
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2314531
06/01/17 12:24 PM
06/01/17 12:24 PM
cudadoug
259 @ .400
done at .585 ...Coil bind or clearance ? Coil bind.
[Re: cudadoug]
#2314897
06/01/17 11:52 PM
06/01/17 11:52 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
New entry radius that fits...
299 @ .500 303 @ .550 312 @ .600 313 @ .650 Yep, with slightly larger valves, multi angle valve job, bowl cleanup and port massage they will go mid 330's real easy...and as much as 319@ .500 lift! Easy stuff!!
Brian Hafliger
[Re: Medlock51]
#2321394
06/15/17 12:44 AM
06/15/17 12:44 AM
sixpackgut
Charleston
What's the biggest lift you can get with stock length valves? What springs will do the job? Specs? 650 is about max with stock rockers. For eagle head alot are using psi1511 or 1515
[Re: cudadoug]
#2406286
11/20/17 12:18 PM
11/20/17 12:18 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Back at playing with these. Holy smokes...we're not even porting just smoothing what is there and trying different valve jobs...
.550 = 311 cfm .600 = 321 .650 = 326
Wow. Sorry but I'm late to the G3 party so...WOW! Been saying it for years!!! Dollar for dollar you CANNOT beat the g3 layout. Easy to make power at a much lower stress engine level. BIGGEST thing is the availability of cheap parts! Matt
