Re: '70 E-Body Ignition Key Light Wiring Question
[Re: 44D6PAKCUDA]
#232142
02/22/09 08:46 PM
02/22/09 08:46 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Three connections to main harness:
1. Yellow with black tracer wire plugs into a single female bullet connector with two yellow with black tracer wires.
2. The pink wire plugs into one of the pink three hole bullet connectors with one pink and one gray wire.
3. The yellow wire plugs into the female bullet connector wit two yellow wires.
Circled in blue.
[Re: Snoopy]
#232146
02/26/09 01:46 PM
02/26/09 01:46 PM
Snoopy-Is that 2983713 harness number,the number on the tag or the part number out of the book?Or are they the same? Is 3513427 a superseded number for the 2983713? Thanks!!
