Page 9 of 9 1 2 3 4 5 6 7 8 9
Re: Still running hot in traffic with the new aluminum [Re: Publicbottle] #232020
09/14/09 10:17 AM
09/14/09 10:17 AM
I had a problem with a 440 in a 56 Dodge pickup. After about 20 min of driving the temp would be at 230. Tried reducing the speed of water through the system with no change at all changed the thermostat. No help. When changing the thermostat noticed a couple of inches under it in the housing there was a hole drilled into the other side (inlet). Tapped and put a 1/4 pipe plug in the hole. That cured the problem. The engine would go up to 195 (that was the thermostat) and not go any higher. Can someone tell me why they drill a hole from the inlet to the outlet side of the water pump housing? Anyway, overheating problem solved!
Re: Still running hot in traffic with the new aluminum rad [Re: Mopar73340] #232021
09/14/09 03:11 PM
09/14/09 03:11 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
I did NOT read every post.
This is an area that seems to be over looked.
Is it running too lean?
What do the plugs look like?
Did you try ti richen it up some?
I had a car 20 years ago that did exactly as you have.
The edelbrock carb was far too lean, richened it up and all was good, even with the air conditioning runnig!!!!!
Re: Still running hot in traffic with the new aluminum #232022
09/15/09 12:02 AM
09/15/09 12:02 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I would like to know more about this solving what sounds to be my problem.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Still running hot in traffic with the new aluminum [Re: Prodart440] #232023
09/15/09 10:58 PM
09/15/09 10:58 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
I'm having an overheating problem as well and I put an infrared heat gun on my exhaust pipes just coming out of the heads and I'm getting 675ish on all but #6 is like 550 and # 5 is so hot it don't read (over 800). Now I'm wondering if maybe my stock cast iron intake manifold is warped or cracked somewhere? I'm also going to try tapping and plugging that hole in the WP housing.
Re: Still running hot in traffic with the new aluminum [Re: Dusted_Ya] #232024
09/16/09 12:11 AM
09/16/09 12:11 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I didn't put a gun to mine, but after holding the RPM's at 2500 for a couple of minuates (in park) the headers were glowing red. Could it be lean, or too much timing? Car runs cool at low speeds, but on the freeway at higher RPM it runs HOT!!
Aaron
68 Coronet 440
Re: Still running hot in traffic with the new aluminum [Re: Prodart440] #232025
09/16/09 10:09 AM
09/16/09 10:09 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Glowing headers sounds too lean.
- Stu Harmon
Re: Still running hot in traffic with the new aluminum [Re: feets] #232026
09/16/09 03:47 PM
09/16/09 03:47 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Too lean or LATE timing can cause it.
I still bet it is way too lean.
Simple to richen it up some to try!!!!
Re: Still running hot in traffic with the new aluminum [Re: fox] #232027
09/18/09 01:04 AM
09/18/09 01:04 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I think I agree on the too lean. I took my distributor to have it checked. It is set at 15* initial and 34* all in by 2500 rpm. If this is right, my headers are now glowing even more. I will try to richen the secondaries and see how that goes. Any other suggestions??
Aaron
68 Coronet 440
Re: Still running hot in traffic with the new aluminum *DELETED* [Re: Prodart440] #232028
04/24/10 09:35 PM
04/24/10 09:35 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Post deleted by AHall
Re: Still running hot in traffic with the new aluminum [Re: AHall] #232029
04/24/10 10:46 PM
04/24/10 10:46 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
What does the converter have to do with running hot.
Re: Still running hot in traffic with the new aluminum [Re: gtx69] #232030
04/24/10 10:55 PM
04/24/10 10:55 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Produces a hell of a lot of heat esp if it is a 4k stall. It would always slip on the street. I don't know how that can really be that streetable.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Still running hot in traffic with the new aluminum [Re: HealthServices] #232031
04/25/10 12:38 AM
04/25/10 12:38 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
But how does that affect the engine?Seems like only the trans would need a good trans cooler
Re: Still running hot in traffic with the new aluminum [Re: gtx69] #232032
04/25/10 12:51 AM
04/25/10 12:51 AM
So Cal
So Cal
You can run a stand alone unit but that is a lot of heat. If the lines currently go into the radiator they are basically heating up the coolant. I just caught the tail end of this thread so I'm not sure exactly what he has for a setup.
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #232033
04/25/10 01:09 AM
04/25/10 01:09 AM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
underdrive pulley? That's what kills my cooling system...
Re: Still running hot in traffic with the new aluminum rad [Re: enelson] #232034
04/25/10 01:30 AM
04/25/10 01:30 AM
So Cal
So Cal
Killed mine too.
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #232035
04/25/10 01:54 AM
04/25/10 01:54 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
My 498 stroker would NOT run cool in traffic...final fix was....alum 26 rad...cheap one...schroud and 7 blade clutch fan..fan half in...half out...this heating problem plaqued Me for 4 years...I am VERY happy with this combo now...car rarely goes over 200...not much over..in long traffic jams in very hot weather
Re: Still running hot in traffic with the new aluminum [Re: feets] #232036
05/01/10 10:13 PM
05/01/10 10:13 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
FEETS- email sent
Re: Still running hot in traffic with the new aluminum [Re: AHall] #232037
05/01/10 10:27 PM
05/01/10 10:27 PM
RapidRobert Online content
RapidRobert  Online Content
Funny thing was id pull off in stop and go and it would go to 185-190 degrees, I get back on the highway (granted doing 70 mph taching 4000 rpm) and it crept to 215-217 degrees and stayed there.
sure sounds like classic inadequate flow in the cooling system (usually the rad) but I'd pull the plugs and check the turning torque required on the front 1&1/4 bolt ASAP right when it's good and hot and maybe 215-217 is not a deal breaker but to me that is too hot.
Re: Still running hot in traffic with the new aluminum [Re: RapidRobert] #232038
05/01/10 10:32 PM
05/01/10 10:32 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I haven't even attempted to read every post on here,...but do you have a fan shroud?
Re: Still running hot in traffic with the new aluminum [Re: JoesMopar] #232039
05/01/10 11:36 PM
05/01/10 11:36 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Went through all of this with by 440 Dart. My overheating problem turn out to be low fuel pressure ala too lean. It would change depending on what day it was, hot at idle one day, hot driving the next. New fuel pump and it was cool...really. Doesn't matter whether it makes sense or not, that's what fixed my overheating.
Russ:)
BigBlock 74 Swinger
