Re: Sweet butchery Pt 2... 5.9 Magnum piston to valve clearance
[Re: Pale_Roader]
#2317039
06/06/17 08:30 AM
06/06/17 08:30 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
That's a lot of clearance taken out and a lot more lift and duration added. I'd clay it and find out.
**Photobucket sucks**
[Re: Pale_Roader]
#2317045
06/06/17 08:58 AM
06/06/17 08:58 AM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Checking it is the only way you will find out. I doubt if it will even be close to enough room. Also, cutting notches in stock pistons is not a good idea because they are already fairly thin where you need the notch. .200 minimum material left after the cut is what my engine guy wanted for milling pistons, and I wouldn't want to go less on a notch either.
[Re: Pale_Roader]
#2317116
06/06/17 12:47 PM
06/06/17 12:47 PM
RapidRobert
if it is all together right now you could swap in a pair of light checking springs & see what you have now for a baseline/start.
[Re: dogdays]
#2317517
06/07/17 08:19 AM
06/07/17 08:19 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
So you bought the cam cause it was cheap. Is the .555 lift with 1.5 or 1.6 rockers? If it's the number for 1.6s, you could swap back to a 1.5 rocker and 0.520 lift.
The problem that I see is there isn't a lot of installed height for a spring to handle that much lift. I seem to remember 1.625 being about max inst6alled height. So 1.625 -0.060 -0.555 = 1.010 solid height for the spring. The Hughes 1110 looks like it hits coil bind at 1.040.
For sure a Comp 901 won't work, unless you go to longer valves.
Glad it's your problem and not mine!
R. Thats .555 with 1.6's (.515" w 1.5). I'd hate to lose the lift (and these rockers are pretty much brand new looking), but if 1.5's are dirt cheap... then yeah, thats an option. And lets be honest... even .515" is gonna make some wild power... Does Hughes (for instance) not sell cams/springs for this application? For stock valves? I'm sure not everyone is buy small cams from them. Surely this issue cant be a hang-up?
[Re: dogdays]
#2318367
06/09/17 08:25 AM
06/09/17 08:25 AM
gregsdart
Others will know better, but from what I have read, with lift much over 1/2 inch you have to use dual springs.
R. Brian from IMM is setting me up with Beehive springs on my EQ heads that will allow higher lifts. They do require a 1.320 diameter valve seat cut of .100 depth to get the extra room for lift. The Beehive retainers then have plenty of clearance for rockers, which can be an issue with some setups.
