Re: 1978 D150 or Lil Red Express grill hardware
[Re: igozumn]
#2317751
06/07/17 06:22 PM
06/07/17 06:22 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
where the top of the grill is attached to the rad support, the screws go directly into the core support. where the lower part of the grill goes into the filler between the fenders, above the bumper, there are nylon blocks the screws go into.
1981 Dodge D150 360 auto
[Re: igozumn]
#2318202
06/08/17 08:08 PM
06/08/17 08:08 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Maybe what you are looking for may be found here?
[Re: igozumn]
#2319193
06/11/17 12:13 AM
06/11/17 12:13 AM
Posts: 76 South East Ontario, Canada
Ramtough
On the parts sheet right at the top, item "1" - retainer - 10 Required. they are #8 Chrome screws, Pan head, about 1 1/4 long, all these trucks usually have the holes striped out, have to dolly holes flat again and hope screws tighten, I have on occasion put screw in hole and hold a screw clip under rad support to tighten them, this can be done through the park light holes and the gap between the support and rad with overflow bottle removed, the screws holding that down has the same problem quite often, these are sheet metal screws and not 1/2 bolts they don't need 1oo ft lbs of torque, just snug.
[Re: igozumn]
#2320588
06/13/17 03:15 PM
06/13/17 03:15 PM
Posts: 1,013 near Kansas City
igozumn
near Kansas City
Went to the local Mopar club show this weekend. 2 Lil Red/Midnight express/warlock/generic trucks there. All seemed to have the same screws along the top of the grill as the cowl panel. Looked just like the interior screws from my FWD Daytonas and Fifth Avenue, lol. Maybe they were allllllll wrong, heh. I put some stainless screws in the cowl, so it's sort of ok the way it is.
Got a pretty good handle on everything. Lower screw holes are hogged out, so a little dolly work to close them back up is in order. This truck is barely a driver. Just need to get stuff attached somehow, someway, but don't want to butcher it anymore than it already is. And if it can be done close to how it should be without too much work, then that's the path we'll take.
Thanks for the help!
