Re: Low boost piston rings
[Re: Clanton]
#2315546
06/03/17 12:44 PM
06/03/17 12:44 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Yes the toll on the bore.summit has hellfire for 166$ I think a n/a ring for 13/14cr is what I am looking for.I want to use low boost and not go for max speed so much as go rounds and use a n/a intake maybe and no boost.
[Re: Clanton]
#2315687
06/03/17 07:16 PM
06/03/17 07:16 PM
Clanton
northern,Ohio,USA
I went to there catalog and that part # is not even close.Looking at M6490 and T6490 ps this is the same ductile,cast iron as hellfire,can you give me other ideas pls!
[Re: Clanton]
#2315720
06/03/17 09:04 PM
06/03/17 09:04 PM
Clanton
northern,Ohio,USA
ok thanks! I looked again and a CS6490 has the steel top,conv 2nd std oil but I will call for info.
[Re: Clanton]
#2315771
06/03/17 11:58 PM
06/03/17 11:58 PM
Clanton
northern,Ohio,USA
I havwe looked up some other brands like Mahl,Wiseco,Ross,Perfect circle most with ductile iron,plasma moly coating cast iron 2nd.perfect circle had a napier 2nd. 3150075-035 Mahle 4355MS Wiseco 4350H Ross RS9798-35 speed pro slp R97985
[Re: Clanton]
#2315792
06/04/17 01:39 AM
06/04/17 01:39 AM
Posts: 2,260 IL
furious70
IL
Don't know if it's helpful, but the 383 in my Fury has been happy enough with 5lbs of turbo boost with what has to be 30yr old ductile rings from a cheap reman house rebuild.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Clanton]
#2315886
06/04/17 11:54 AM
06/04/17 11:54 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I am in the process of installing a new set of S/S custom top rings for my turbo small block, I discovered moly coming apart on my old set, mild engine, conservative tune, pump gas. I have an odd bore size so they had to be custom from Total Seal.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
