Offset grindin SB crank?
#231507
02/21/09 05:16 PM
02/21/09 05:16 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
How much can a good std journal 273 crank be offset ground? Can it be ground down engough to use the honda rods? There are no holes in the throw so it should be OK right?
Re: Offset grindin SB crank?
[Re: dizuster]
#231509
02/21/09 07:15 PM
02/21/09 07:15 PM
HotRodDave
Kalispell Mt.
I figured 1. I have it, 2. it is forged 360 is cast, 3. with the small journals it would be pretty light and lots of dirt cheap NASCAR rods on e-bay with that journal size in pretty long lengths so I could run a light weight piston also. According to my calculations it could go to 3.55 stroke, is this remotely close? With a long rod in my 340 block .020 over it would be a rev happy 360 ish Also this crank is for a 4spd and a 360 4spd crank aint easy to find. It is just a though since I already have it.
[Re: HotRodDave]
#231511
02/22/09 12:09 AM
02/22/09 12:09 AM
Posts: 27,465 So Cal
autoxcuda
So Cal
Good question. I wonder if you could adapt Chevy SB honda sized rods. Could would you have any room to ALSO offset grind the journal, if so how much?
The circle track guys use some super lightwieght ones that I think would live in a Sub 400 HP street motor.
[Re: HotRodDave]
#231512
02/22/09 01:48 AM
02/22/09 01:48 AM
you'll effectively destroy an otherwise good crankshaft if you take it to 1.88 journal size on an offset grind for the aforementioned reasons. the oiling holes will be right at the cheek of the fillet.
#231513
02/22/09 04:44 AM
02/22/09 04:44 AM
autoxcuda
So Cal
So an offset grind with honda journals is a no-go. But just grinding down to a honda journal is ok on the oiling hole placement??
[Re: autoxcuda]
#231514
02/22/09 07:39 AM
02/22/09 07:39 AM
no, either way will be a problem.
[Re: dizuster]
#231515
02/22/09 02:17 PM
02/22/09 02:17 PM
HotRodDave
Kalispell Mt.
Are 2 inch chevy rods ok?
[Re: autoxcuda]
#231516
02/22/09 06:14 PM
02/22/09 06:14 PM
autoxcuda
So Cal
Thanks.
Now the stock big block cranks don't have a problem going to honda journals? Is that correct?
[Re: autoxcuda]
#231517
02/22/09 06:24 PM
02/22/09 06:24 PM
Thanks.
no, that's not correct. if the manufacturer plans from the beginning to go to 1.88 rod journals, the drill the oiling holes in the proper place to start with. to do it after the fact by reducing a 2.375 journal down to a 1.88 you'd be removing .495". the oiling hole would be coming out the side of the radius on the crank.
for the crank in question, yes, IMO a 2.00 rod journal is doable.
#231518
02/22/09 06:48 PM
02/22/09 06:48 PM
Posts: 3,395 Pa
Hot 340
Pa
Thanks.
You sure Dan? I was just downstairs looking at my steel sb crank and if you removed .250 off the face of the journal by the oil hole(.495 total dia) it wouldnt bring the hole near the fillet..
[Re: Hot 340]
#231519
02/22/09 07:51 PM
02/22/09 07:51 PM
Thanks.
your talking about a smallblock crank and someone else mentioned a BB crank. for the sb crank you'd remove .245 total. if you offset grind it then more will come off the bottm half than the top. either way, i wouldn't do it. i'm just relaying what i've personally seen, your results may vary.
[Re: 69Cuda340S]
#231521
02/23/09 09:41 AM
02/23/09 09:41 AM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
An off the shelf 3.79" stroke crank is available with 318/340 mains. I believe Mopar Performance sells it.
MP does'nt offer it anymore, but Callies & K1 both make a 3.79, but both have a 2.10" GM rod journal.
We do about 10 offset ground stroker cranks a year going to 2.0" Journal, most stuff can not go further unless the forging was intended for it.
We just DE-stroked a Callies 3.58" down to 3.48" a few weeks ago.
Stock 3.31" crank should have no problem going to 2.0"
[Re: HotRodDave]
#231525
02/23/09 06:38 PM
02/23/09 06:38 PM
Posts: 752 North Dakota
Jesse_Lackman
super gas
super gas
North Dakota
Yes. If ground to HRJ with max offset the rod oil holes will be in the same place as if you ground the rod journals to a normal undersize. I'll have to check what the stroke increase is.
[Re: HotRodDave]
#231527
03/01/09 10:21 AM
03/01/09 10:21 AM
Posts: 4,206 New York
polyspheric
New York
If the offset is maximum (all surfaces new to start) the diametric difference is the stroke difference. 2.123" - 1.8885" (Manley data) = .2345" 3.31" > 3.5445"
However, usually .005" is left for clean-up.
Boffin Emeritus
