Whats with my brakes
#2308897
05/22/17 02:10 AM
05/22/17 02:10 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
04 dodge 3500 dually , while setting at a stoplight with the brake applied the brake peddle starts to pulsate like its trying to throw up, then the peddle goes down. Only did it a few times, other wise the brakes work ok. The front pads are in good condition, the rears are new . Whats up?
Re: Whats with my brakes
[Re: rowin4]
#2309128
05/22/17 03:20 PM
05/22/17 03:20 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
If it were mine, I'd run to the dealer and have the ABS system scanned. 2ยข
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: rowin4]
#2309632
05/23/17 10:08 AM
05/23/17 10:08 AM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
You do have an ABS problem there. Probably the unit, take it to the dealership and have it diagnosed. Those trucks use the ABS for the vehicle speed so you do need it.
[Re: Guitar Jones]
#2310393
05/24/17 03:10 PM
05/24/17 03:10 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I dunno. How does the ABS make the pedal drop? More like a MC bypassing internally.
[Re: rowin4]
#2310722
05/25/17 01:46 AM
05/25/17 01:46 AM
rowin4
The interesting thing is that while slight pressure is applied , just what you need to hold the truck at the stop light , the peddle starts to push back up and then pulsates as I said like it's going to throw up , then the peddle sinks down . How does the ABS work with vehicle speed?
[Re: rowin4]
#2310754
05/25/17 04:16 AM
05/25/17 04:16 AM
Guitar Jones
The abs module uses the wheel speed sensors and then broadcasts that info to the pcm and cluster.
[Re: John_Kunkel]
#2310756
05/25/17 04:19 AM
05/25/17 04:19 AM
Guitar Jones
I have replaced a lot of abs units in the early Genesis cars for that very condition. You would think it's a master cylinder but it's not.
[Re: rowin4]
#2310848
05/25/17 11:52 AM
05/25/17 11:52 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Sounds like your hydroboost is suspect. Look at the ps pump pressures and or the booster
**Photobucket sucks**
[Re: rowin4]
#2310861
05/25/17 12:17 PM
05/25/17 12:17 PM
rowin4
Mentioning power steering is interesting. When my rack developed a seal leak the power steering fluid went low. When the brakes were applied the pump would wine. Wondered why the brakes would be somehow connected to power steering.
[Re: rowin4]
#2311118
05/25/17 07:33 PM
05/25/17 07:33 PM
70Cuda383
Marysville, O-H-I-O
They absolutely are connected. The power steering pump operates both.
Pressure comes out of pump and goes to hydroboost on the firewall. From there it goes through the booster and down to the steering box.
[Re: rowin4]
#2312286
05/28/17 09:45 AM
05/28/17 09:45 AM
Guitar Jones
I don't see the hydro boost unit causing the pedal to push back like that. That is something an ABS pump would do.
Also you say the pedal goes down after this happens but you didn't say if it goes down to the floor, lower than normal or just back down where it was.
What kind of noise does it make when this is happening?
[Re: rowin4]
#2312354
05/28/17 12:36 PM
05/28/17 12:36 PM
rowin4
it goes down more than normal , still have brakes. No noise or change on engine sound that i recall.
[Re: rowin4]
#2314970
06/02/17 02:16 AM
06/02/17 02:16 AM
70Cuda383
Marysville, O-H-I-O
Guess it depends on what exactly it feels like, which we can't tell over the Internet.
I can say that mine was pulsing a bit. It's a lighter, but faster pulse than ABS. if and pulsing is like a runner breathing after a 100 yard sprint 'deep and heavy' then what I was feeling was like a dog panting--rapid and shallow.
Don't know how else to describe it, but it was absolutely due to a failing hydroboost and weak PS pump. My guess was the failing hydroboost put debris into the system and killed the pump. I replaced the pump, the steering gearbox, the hydroboost all at once, and flushed out the lines and PS Cooler. Pulsing pedal went away after that, never touched the ABS stuff
