69 RR Convertible with Power Windows #2312086
05/27/17 06:52 PM
05/27/17 06:52 PM
cbusters Offline OP
cbusters  Offline OP
69 Road Runner non-rally gauge set. I have seen the "breaker" that mounts on the back of the Ammeter that is the same setup on a convertible or on a set of power windows. This is where the hot lead attached for each of those options. What is the configuration when you have both? I didn't see a place for a second breaker to be installed and would not want to guess and start melting wires. Any pictures would be great and thanks!
Re: 69 RR Convertible with Power Windows [Re: cbusters] #2312251
05/28/17 04:37 AM
05/28/17 04:37 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
On my '69 Coronet Convertible with power windows, I think only the windows have the circuit breaker? I'll have to check the wiring diagram, but I don't recall seeing a circuit breaker for the convertible top?
This has the rally dash.
Re: 69 RR Convertible with Power Windows [Re: 451Mopar] #2312668
05/28/17 11:37 PM
05/28/17 11:37 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Isnt the circuit breaker for the top pump motor behind the driver side kick panel?
Re: 69 RR Convertible with Power Windows [Re: cbusters] #2312693
05/29/17 12:19 AM
05/29/17 12:19 AM
cbusters Offline OP
cbusters  Offline OP
I just have a harness going up the kick panel, but the car has been apart for 30 years. I was about to send the gauges off to be redone and I thought I remembered them both having the same breaker setup. Long term memory must be fading.
Re: 69 RR Convertible with Power Windows [Re: cbusters] #2312751
05/29/17 02:09 AM
05/29/17 02:09 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
A circuit breaker on each circuit would be a good idea either way.
I like the Dragons Lair Avatar smile
