The right bearings for a steel crank
#2312264
05/28/17 06:41 AM
05/28/17 06:41 AM
Posts: 6 Germany
MarcoM
Germany
A friend of mine rebuild a 440 with a 69er RR steel crank. Can he use the federal mogul 2320 CP 10 bearings or are they only for cast cranks?
65 Chrysler Windsor 2 door 74 Dodge Charger 440, 4 Speed
Re: The right bearings for a steel crank
[Re: MarcoM]
#2312271
05/28/17 07:57 AM
05/28/17 07:57 AM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
No difference, basic tri metal is ok for both. Those are fine, he can use them. Clevite P bearings are usually fine too. Usually a change to different bearing material would be because of use, not crank material.
Rich H.
Esse Quam Videri
[Re: MarcoM]
#2312395
05/28/17 02:10 PM
05/28/17 02:10 PM
Posts: 6 Germany
MarcoM
Germany
Thank you guys for the quick response :-)
[Re: MarcoM]
#2312486
05/28/17 05:36 PM
05/28/17 05:36 PM
Posts: 4,210 New York
polyspheric
New York
In theory, an iron crank may be a few Rockwell C scale numbers softer and benefit from a softer bearing to more easily embed minute particles, but I don't think it's significant for anything but industrial/commercial use.
Boffin Emeritus
