6.4 hemi crank offset grind #2312327
05/28/17 11:36 AM
05/28/17 11:36 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
has anyone done one yet? it should be able to go to 3.90 if cut for a 2 inch journal. does any know if the 6.4 crank will take a Honda 1.88 journal.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 6.4 hemi crank offset grind [Re: ric3xrt] #2312595
05/28/17 08:55 PM
05/28/17 08:55 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Just did one to 3.79. I believe 3.90 would be possible with a Honda journal. All depends on the oiling holes.
Matt
Re: 6.4 hemi crank offset grind [Re: ric3xrt] #2312598
05/28/17 08:58 PM
05/28/17 08:58 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
You won't get to 3.900 by going to a 2.000 journal, maybe 3.830.
I have a 6.1 crank that I had ground to 3.795 with a 1.888 rod journal, I would have to see the oil passages in a 6.4 crank to see if it could be done
Re: 6.4 hemi crank offset grind [Re: ric3xrt] #2312648
05/28/17 11:10 PM
05/28/17 11:10 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What kind of power can a small journal like that handle?
Re: 6.4 hemi crank offset grind [Re: WO23Coronet] #2312655
05/28/17 11:21 PM
05/28/17 11:21 PM
USA
hudsonhornet7x Offline
USA
Nascar uses a small journal like that, but I would be more worried about overlap.
Also, the nitriding of the crank would be long gone by the time you cut one down that far.
Re: 6.4 hemi crank offset grind [Re: WO23Coronet] #2312846
05/29/17 10:45 AM
05/29/17 10:45 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
from what I've been reading a lot of it depends on stroke length , the longer the stroke the less power.
Some interesting discussing's about it on different websites, Yellow bullet for one.
