Page 4 of 6 1 2 3 4 5 6
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: RylisPro] #2295910
04/29/17 02:15 AM
04/29/17 02:15 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By RylisPro
Goody do you have the rubber boots for those heim joints?
Seals it RERS3. You need 10 for the Hotchkis kit
It helps to have them for longevity
Yep, I did boots on the tie rods, UCAs and strut rods. They are not the most fun to work with, but I can really see them helping improve the life of the joint. Road grime and brake dust is not good for much of anything.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2300953
05/08/17 12:08 AM
05/08/17 12:08 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Progress has been slow lately but I am spooling back up a little sprint on work for the next few weeks.
I managed to get a $250 set of Aeromotive fuel rails off of an Amazon price dip for $95. Unfortunately they come in a horrid anodized red, which would screw up my feng shui! I picked up some new injectors and treated the rails to a coat of gunmetal grey to help blend in a little better. Along with that, I have kicked off the fuel system by mocking up the TanksInc tank in the car. The JakeFab puck is close, but appears to fit under the floor.
I have some basic lines made up to the filter/regulator and will work on a rollover vent mount as well. The 6AN fuel line routes along the passenger rail [previous post] and witin the subframe connector. That was made possible by some very early planning when things went together, so far it seems to be just right.
I also finished up the installation of my Hotchkis rear sway bar, I needed to weld on the chassis mounts for it. I wanted to make sure my line routing accounted for all of those parts back there.
That's all for now!
2020 RAM 1500
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2301078
05/08/17 11:41 AM
05/08/17 11:41 AM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
It's nice to see it coming together for you.
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2302855
05/11/17 02:30 PM
05/11/17 02:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looking great!
Your MS3 should be able to handle your fuel pump PWM. that you want to do. You will have to use a solid state relay for the pump obviously but there is settings to control your pump PWM. I have run into some fuel heating issues and I want to try it but I have not gotten around to it just yet.
68 Barracuda Formula S 340
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: Bad340fish] #2303035
05/11/17 09:35 PM
05/11/17 09:35 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By Bad340fish
Looking great!
I would need an ISO 280 solid-state relay, which I am not sure exists. I will likely do PWM for the fuel pump at some point, actually, I initially planned to. For now, I am running behind enough that I have parked some of the non-essential tasks to get the car on the road. That's a project for a weekend after the car is running well.
2020 RAM 1500
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2303883
05/13/17 04:48 PM
05/13/17 04:48 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Once they make noise they do get easier to stay motivated. I am sure you know more about the relays than I do but at one time I was pointed to one for a reasonable cost that could(or is supposed to) do the job. If I come across that part I'll post it.
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2309607
05/23/17 08:52 AM
05/23/17 08:52 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I am creeping up on a fully wired and validated electrical system, which is a pretty big milestone for me. I can talk to the Megasquirt and load tunes, make changes and test some of the systems.
Hopefully these videos work:
Tach test
https://youtu.be/hgHusDZX7js
Coil test
https://youtu.be/lZwj3mgxLwQ
Injector test [all, sequential injection]
https://youtu.be/D2c9FWe1JZI
2020 RAM 1500
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2310102
05/24/17 12:10 AM
05/24/17 12:10 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The test modes on the MS are pretty awesome. I just discovered I had a bad coil(I run 8 LS coils) and the test mode was nice to help confirm where the actual problem was.
When the engine is running you can also deactivate injectors and coils to determine if things are working properly.
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: Bad340fish] #2311730
05/26/17 08:06 PM
05/26/17 08:06 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I haven't seen the deactivate one before, that's pretty neat.
2020 RAM 1500
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2314403
06/01/17 12:18 AM
06/01/17 12:18 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
First attempt to start it was successful!
Hopefully the video works
https://youtu.be/QSDveBUH5e8
2020 RAM 1500
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2314712
06/01/17 05:57 PM
06/01/17 05:57 PM
Boca Raton, Florida
jpilone Offline
jpilone  Offline
Boca Raton, Florida
Awesome! That's the best sound...
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2318572
06/09/17 06:29 PM
06/09/17 06:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Wow, car has certainly come a long way.
I remember reading on this very board when you bought this car
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2319417
06/11/17 02:02 PM
06/11/17 02:02 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Attention to detail is amazing, love this thread. great job.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: ric3xrt] #2325992
06/24/17 01:56 AM
06/24/17 01:56 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This was certainly the first place I stopped when I bought the car in November of 2004. The car is in a far better state today than I could have ever imagined back then!
Thank you! I have exhibited some level of OCD symptoms throughout this process, hopefully for the better. I tend to worry about things most people never pay attention to. fan
The car was rolled out of the garage for the first time on its own wheels in three years. It seems like an eternity. I expect the back end to go back down like it should once I have a full 3" exhaust, seats, glass and a battery in the car, it's sitting a bit high for my liking.
My garage is getting air conditioning this weekend so that I can get this car finished this Summer!
19420655_1577960538914665_2372395535662860805_n.jpg19400184_1577960532247999_3405681647520766435_n.jpg
2020 RAM 1500
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2327710
06/27/17 09:36 PM
06/27/17 09:36 PM
Medford OR
FrankenScamp Offline
Medford OR
bow punkrocka
Man, it's getting closer! Great job thus far. beer
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2329394
06/30/17 11:51 PM
06/30/17 11:51 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It's getting quite close to driving now!
Sorry for the early pictures in this thread being no longer valid. The forum won't seem to let me edit/fix the links, so I may have to restart this thread elsewhere wrench
2020 RAM 1500
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2330545
07/03/17 08:35 AM
07/03/17 08:35 AM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
Congrat Mike, I bet you can't wait.
Maybe a moderator can help you update the invalid pics?
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2334395
07/09/17 11:21 PM
07/09/17 11:21 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I briefly pulled it out of the garage under it's own power today and let it get to full operating temp.
Lots of EFI tuning to do yet and I am working on getting everything else in the car asap.
2020 RAM 1500
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2335656
07/12/17 12:31 AM
07/12/17 12:31 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
work Hmmmm......I'm gonna go out on a limb here, and bet your screen name on the young dads message board is GOODYSGOTACUTIE! biggrin up
Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda] #2339335
07/18/17 09:04 PM
07/18/17 09:04 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
https://www.youtube.com/watch?v=Dn1dQ8Crz_o
I did a little driving yesterday, moving forward with it!
2020 RAM 1500
