Re: Which 6 Pack Intake Did 1970 Superbirds Have ?????
[Re: blewbyu]
#2308477
05/21/17 01:45 PM
05/21/17 01:45 PM
Posts: 43,214 Bend,OR USA
Cab_Burge
They could have had either one, I think It has been said on here that Mopar ran out of the cast iron intakes and switch back to the Eddy aluminum ones around the beginning of December 1969 Maybe another internet myth I had a 1970 V code Charger that the scheduled production date was 10-23-69, it was sold new in the town I lived in in SO CA(Victorville) and it had a cast iron intake on it, I ended up buying the car years later and it was missing the original carbs and intake and Dana 60 by then. I found three other intake and carbs with casting dates in early October of 1969 real easy so one of them ended up on that motor IHTHs
[Re: blewbyu]
#2308985
05/22/17 12:04 PM
05/22/17 12:04 PM
Posts: 1,318 Ohio
jlatessa
Ohio
See if my info correlates with any other peoples knowledge;
I bought an A12 in 1969 from a performance dealer in Cleveland that my buddy sold for.
He specialized in the sales of MOPAR performance during the time when it was exciting. we also raced a sponsored car for them each year at Thompson Drag raceway.
I remember him saying that in 70, when the cast Iron manifolds started appearing, the 4 speeds got Al. and autos got Iron.
I never had this confirmed so it's hearsay, but if anyone was an ORIGINAL owner, they can chime in.
Just my memory, don't kill the messenger!! LOL
Joe
[Re: jlatessa]
#2309264
05/22/17 07:13 PM
05/22/17 07:13 PM
Posts: 4,283 Florida
blewbyu
Joe The reason I asked this question is I recently purchased a Superbird from an owner that owned it for 43 years. It is a 4 speed car and has an Aluminum Edelbrock 6 pack intake and was trying to figure if it was correct. The owner says it was on there when he purchased the car used. The carbs are correct for the car. (They could have had either one, I think confused It has been said on here that Mopar ran out of the cast iron intakes and switch back to the Eddy aluminum ones around the beginning of December 1969 shruggy Maybe another internet myth work I had a 1970 V code Charger that the scheduled production date was 10-23-69, it was sold new in the town I lived in in SO CA(Victorville) and it had a cast iron intake on it, I ended up buying the car years later and it was missing the original carbs and intake and Dana 60 by then. I found three other intake and carbs with casting dates in early October of 1969 real easy so one of them ended up on that motor shruggy IHTHs) The K frame date is 3429 which is Dec 21st of 69 so if what you say is true this could also apply as is the 4 speed theory.
[Re: B5 Bee]
#2309577
05/23/17 05:00 AM
05/23/17 05:00 AM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
there have been a couple of rumors about WHY some late-Oct./early-Nov. 440+6 intakes are aluminum supply or bad quality/porosity issues with cast iron version causing a shortage of usable parts I know of a first week of November "scheduled" Challenger R/T w/18K miles - figuring some Actual Production Dates might help shed some light on the subject. I've heard of aluminum intakes from Lynch Rd. & Hamtramck what about St. Louis & LA?
[Re: blewbyu]
#2309578
05/23/17 05:00 AM
05/23/17 05:00 AM
Posts: 1,187 USA
big-block-dave
USA
Any pics of this bird? What color is it?
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: big-block-dave]
#2309677
05/23/17 11:15 AM
05/23/17 11:15 AM
blewbyu
Any pics of this bird? What color is it? She's in primer on outer body, jams and under hood still original color of FJ5. Don't even ask about the hoopty rims, they have been removed as soon as it came off the trailer. Car has been with the same owner for 43 years but has set for years and needs the usual stuff to make it road worthy, brakes, fuel system and carbs rebuilt.
[Re: 6bblgt]
#2309682
05/23/17 11:20 AM
05/23/17 11:20 AM
blewbyu
there have been a couple of rumors about WHY some late-Oct./early-Nov. 440+6 intakes are aluminum supply or bad quality/porosity issues with cast iron version causing a shortage of usable parts I know of a first week of November "scheduled" Challenger R/T w/18K miles - figuring some Actual Production Dates might help shed some light on the subject. I've heard of aluminum intakes from Lynch Rd. & Hamtramck what about St. Louis & LA? Of course its a Lynch Rd car SPD is B30 but K frame date is 3429 and caliper dates are 329 which I would imagine would give a close date of actual production.
[Re: blewbyu]
#2309927
05/23/17 06:20 PM
05/23/17 06:20 PM
6bblgt
Las Vegas, NV
Superbirds actual are pretty easy with their travel to Clairpointe documented daily flow to/from Clairpointe B30 = Nov. 30, 1969 3429 = Dec. 8, 1969 329 = 32nd week of '69 = Aug. '69 or (3299) Nov, 25, 1969 can you share VIN and/or fender tag info?
[Re: blewbyu]
#2309959
05/23/17 07:25 PM
05/23/17 07:25 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Both my four speed A12 1969 Runners had Aluminum Intakes, 1970 Cuda four speed 440-6 built around Late Oct. first days of Nov. Cast Iron intake, 1970 440-6 Runner four speed cast iron intake. The car I have raced at the Drag Strip 1969 A12 Super Bee late built car, motor was assembled in mid May of 1969 car likely assembled in June or maybe early July SPD of 426 does not tell date when it was built but will have to look at the broad cast sheet for more details and never looked at the other date codes such as K member. Looked at a lot of Cudas, Chargers, Challengers, and Super Birds and Runners and Bees in the seventies and all came with cast iron intakes. Never looked at a 1970 Fury.
Do not know why Chrysler decided to shut down the 1969 Plymouth A12 build so early and continue building the 1969 Dodges A12s.
1971 HEMI E BODY REGISTRY
[Re: 6bblgt]
#2310054
05/23/17 11:00 PM
05/23/17 11:00 PM
blewbyu
[Re: hemicar1971]
#2310162
05/24/17 02:40 AM
05/24/17 02:40 AM
Posts: 1,070 Ohio
C_B5
Ohio
Looks like it was built in the first batch. Not certain what you are basing the "built in first batch" on. If the VIN is RM23V0A170843 (the last # is hard to confirm in the photo) From the Superbird production list is bird number 1679. This would place it towards the end of the run. Further the date listed for this car to be received at the Clairpointe assembly facility is Dec 11 and shipped on Dec 12. Again from the factory production list, the the latest date for Superbirds to be assembled and shipped are all Dec 17-18. The original paperwork had a completion date for ALL cars by Dec 23, 1969
[Re: C_B5]
#2310248
05/24/17 10:33 AM
05/24/17 10:33 AM
blewbyu
Looks like it was built in the first batch. Not certain what you are basing the "built in first batch" on. If the VIN is RM23V0A170843 (the last # is hard to confirm in the photo) From the Superbird production list is bird number 1679. This would place it towards the end of the run. Further the date listed for this car to be received at the Clairpointe assembly facility is Dec 11 and shipped on Dec 12. Again from the factory production list, the the latest date for Superbirds to be assembled and shipped are all Dec 17-18. The original paperwork had a completion date for ALL cars by Dec 23, 1969 You seem to have a lot of knowledge or some facts about the build on theses cars. Where does one find information about these cars or is it years of searcher on your part? I have some other questions on these cars and would like some clarification on other aspects of them being built since this is first time I have messed with a Superbird. Thanks for any info that has been shared.
[Re: blewbyu]
#2310257
05/24/17 10:55 AM
05/24/17 10:55 AM
Posts: 10,731 North Dakota
6PakBee
North Dakota
...It is a 4 speed car and has an Aluminum Edelbrock 6 pack intake and was trying to figure if it was correct. First question, is it the factory Edelbrock intake or is it the aftermarket version? Identification
