Re: Early AVS question
[Re: wedgeheaded]
#2304988
05/15/17 05:30 PM
05/15/17 05:30 PM
RapidRobert
fit one of those thin red straws to the nozzle on a can of brake kleen & take out the screw & get the straw up in there & shoot a good 3 second blast into it then replace the screw to where it was.
[Re: wedgeheaded]
#2305096
05/15/17 08:10 PM
05/15/17 08:10 PM
RapidRobert
The idle passages are the smallest in the carb & logically can plug up the easiest. Longer shot it might even possibly be a module or pickup that is acting up. Holler how it turns out/what it was.
[Re: RapidRobert]
#2305114
05/15/17 08:30 PM
05/15/17 08:30 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
I just sent the original Carb for my big block GTS to Scott for a resto.
Abe Lincoln
[Re: wedgeheaded]
#2305219
05/15/17 11:11 PM
05/15/17 11:11 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
If your carb is running great and there's a sudden change, chances are you've got a fuel contamination issue.
Although a major hassle, sometimes its best to just remove the entire fuel system from the tank forward (tank, pickup, fuel lines, fuel pump, filter, carb, etc.) to either restore or replace each item. T
The culprit these days is most commonly bad fuel which can solidify into small chunks when it sits for long periods of time causing all sorts of problems. It can also be rust and scale, etc. Once its all cleaned up you shouldn't have further issues.
The single air bleed screw is not a good design for fine tuning which is why it was short lived (1968 and part of 69). It basically balances the air supply to each side of the carb (also notice how it turns in the opposite direction). The trick is gaining access to the two lower mixture screws (which they all have, usually hidden by a factory installed lead plug). If you remove the plugs and gain access to the small screws you can adjust them, or replace them with two normal mixture screws and set springs allowing you to make finer adjustments just like later versions. .02
[Re: ScottSmith_Harms]
#2305239
05/15/17 11:58 PM
05/15/17 11:58 PM
Posts: 15,503 Omaha Ne
TJP
Omaha Ne
[Re: wedgeheaded]
#2305393
05/16/17 10:31 AM
05/16/17 10:31 AM
Posts: 1,581 Friendly, WV
wedgeheaded
Friendly, WV
I'm plan to dig into it tonight. I'll keep you all posted. I have the car listed on craigslist and hope to have it in the car corral at the Columbus Classic on sat. Fingers Crossed.
[Re: wedgeheaded]
#2305471
05/16/17 01:31 PM
05/16/17 01:31 PM
RapidRobert
If you get into those lower passages I would blast them out too with brake kleen.
[Re: wedgeheaded]
#2305850
05/17/17 01:45 AM
05/17/17 01:45 AM
Posts: 1,546 Seattle, WA
375inStroke
Special needs person
Seattle, WA
I had the same problem with my Charger, a Sep. 68 build. Ran fine, then like crap. Blew carb cleaner through mixture screws, and ran fine. Later ran like $#!t again. Pulled top off, and there was a bunch of flakey junk in the float bowl. Sucked it out, blew carb cleaner through the passages I could get to on the car with the top off, and it's ran great since. I'd take the lead plugs off so you can adjust the idle screws. They look like this. This is what I used to get them out. The little screws are sprung out a bit on the slotted end, so they apply enough friction to keep them fixed where you turn them.
[Re: wedgeheaded]
#2306593
05/18/17 11:16 AM
05/18/17 11:16 AM
wedgeheaded
Friendly, WV
OK, now it's flooding. I'm going to use a 7/16 drill bit and check my float levels. I know this is all just part of owning a car that's nearly 50 yrs old but it gets old. I'll keep you posted. I think this should do it though.
[Re: wedgeheaded]
#2306615
05/18/17 11:45 AM
05/18/17 11:45 AM
RapidRobert
that seems to happen alot when the slow/steady flow of fuel in normal operation changes to a fast gush when the lines have been opened & an air gap created then it is reconnected & the gas rushes up to the needle/seat. I just had this happen on a rebuild on a Holley 2bbl. it will pass. I read once that the rush kicks up minute dirt particles in the system.
