What does a 426 Drag Pak motor dyno at? #2305793
05/16/17 11:44 PM
05/16/17 11:44 PM
USA
hudsonhornet7x Offline OP
USA
I am curious as to what power and torque a naturally aspirated 426 Drag pak type of engine makes.
Re: What does a 426 Drag Pak motor dyno at? [Re: hudsonhornet7x] #2306128
05/17/17 03:25 PM
05/17/17 03:25 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
That may be even harder to find out than the production Drag Pak cam specs. biggrin
Re: What does a 426 Drag Pak motor dyno at? [Re: hudsonhornet7x] #2306138
05/17/17 03:43 PM
05/17/17 03:43 PM
USA
USA
Just looking for general numbers!
Re: What does a 426 Drag Pak motor dyno at? [Re: hudsonhornet7x] #2306149
05/17/17 04:19 PM
05/17/17 04:19 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Is this something you can find out from nhra. Dont the weight breaks go something like 6.5lbs per hp in factory stock
Re: What does a 426 Drag Pak motor dyno at? [Re: hudsonhornet7x] #2307549
05/19/17 07:46 PM
05/19/17 07:46 PM
Renton Washington
Triple Threat Offline
Renton Washington
The Ratings from NHRA are basically useless since they are rated Horsepower, not actual dyno figures.
Best off to look at weight and MPH to determine HP with a calculator.
Stock/SS cars are extremely efficient and scienced out, so if the calculator tells you they're making 900, it might be closer to 850 in the real world.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What does a 426 Drag Pak motor dyno at? [Re: hudsonhornet7x] #2307623
05/19/17 09:44 PM
05/19/17 09:44 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think Barton still has the FS/B record at 156mph@3400lbs iirc.
Mopar to the bone!!!
Re: What does a 426 Drag Pak motor dyno at? [Re: hudsonhornet7x] #2307791
05/20/17 09:41 AM
05/20/17 09:41 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
We supply coatings to a GM nascar builder, in a few bench racing conversations, with one of his guys who runs a COPO 427 NA is doing around 1.7 to 1.85 HP per cu in, so you figure he's making between 725-780,according to him.... , now this engine builder has told me, he figures Barton is up around 790-810
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: What does a 426 Drag Pak motor dyno at? [Re: hudsonhornet7x] #2307972
05/20/17 03:06 PM
05/20/17 03:06 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Are there any NA Fords or are they just supercharged?
Re: What does a 426 Drag Pak motor dyno at? [Re: hudsonhornet7x] #2308283
05/21/17 01:06 AM
05/21/17 01:06 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think they let them run a Windsor based engine. 7.0L is engine size allowed and I don't think DOHC Ford engines can get that big.
Re: What does a 426 Drag Pak motor dyno at? [Re: ric3xrt] #2309670
05/23/17 11:00 AM
05/23/17 11:00 AM
P
PorkyPig Offline
PorkyPig  Offline
P
S.A.M. Racing (School of Automotive Machinists) says a 427 LS7 COPO makes 730 to 740 HP from GM and the work they did to theirs has made 825 HP.
