Rpm potential #2305398
05/16/17 10:42 AM
05/16/17 10:42 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
What kind of rpm are guys turning with say a .600 lift hydraulic roller in these engines? NA vs Boosted make any difference?
Re: Rpm potential [Re: fbs63] #2305917
05/17/17 09:06 AM
05/17/17 09:06 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I've read about people going as high as 6500-7000 stock rockers, not sure about cam profiles on them, David Barton has gone over 8k but I have no clue as to cam and rockers.
I have a kid who works for me here that has a 06 magnum, 392 inch 5.7 , 4 in bore 3.9 stroke , Eagle heads runs a RLD- H5 cam Lift is 605/.611, stock rockers ,I've personally seen hit 7200 ,now he's running a set of PRW PQX steel rockers and is turning up to 7500.
I think the crank is more of an issue then valve gear from some of the things I've read here on moparts
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Rpm potential [Re: ric3xrt] #2305936
05/17/17 10:18 AM
05/17/17 10:18 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
I deal with a shop that does a few Drag Pak engines. The original 6.1 cranks were cross drilled and that was the oiling issue. Just was wondering what was a common rpm for these engines with a hydraulic roller. Had no idea anyone besides T&D and Jesel were making rockers. Harland Sharp doesn't show them on their site. Thanks for the info.
Re: Rpm potential [Re: fbs63] #2305947
05/17/17 10:37 AM
05/17/17 10:37 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
New Jesels that don't require machining and PRW
Re: Rpm potential [Re: 496 A-body] #2305950
05/17/17 10:50 AM
05/17/17 10:50 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Anyone have the pn for the Jesel Drag Pak rockers?
Re: Rpm potential [Re: fbs63] #2305980
05/17/17 11:44 AM
05/17/17 11:44 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
What's the story on PRW rockers?
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Rpm potential [Re: Quickrunner] #2305990
05/17/17 11:57 AM
05/17/17 11:57 AM
USA
hudsonhornet7x Offline
USA
Yes I would like to know that as well.
Re: Rpm potential [Re: Quickrunner] #2305991
05/17/17 12:01 PM
05/17/17 12:01 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
They don't look bad but they are $1169 at Jegs. Part # 3234513. Limited to 450 open pressure. I'd pay the 2k for Jesel Drag Pak or $2800 for T&D before I paid that for Chinese rockers.
Re: Rpm potential [Re: fbs63] #2306086
05/17/17 02:21 PM
05/17/17 02:21 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Where did you find the Info about open pressure? (just curious)
When Eddie gets back from lunch I'll ask him what springs are in his magnum.
Re: Rpm potential [Re: ric3xrt] #2306115
05/17/17 02:51 PM
05/17/17 02:51 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
On PRW's website.
Re: Rpm potential [Re: fbs63] #2306131
05/17/17 03:29 PM
05/17/17 03:29 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I kept getting a 404 code when I went to their site.
My magnum kid says the springs are what ever was on the Hughes heads he bought , he thinks they are 340/350 open they are a beehive spring.
