5.7L with a bad cam #2302054
05/09/17 10:49 PM
05/09/17 10:49 PM
SC
V194 Offline OP
V194  Offline OP
SC
Found a salvage yard telling me they have a 5.7l core 2011 I think. They indicate the engine has a bad cam and will need new cam and cam bearings. What might have gone wrong. Any danger in picking this thing up and replacing the cam and bearings and using it. What might I be getting into?
Re: 5.7L with a bad cam [Re: V194] #2302382
05/10/17 02:08 PM
05/10/17 02:08 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Did they actually inspect the cam? I have lifters go bad on ones I've used, but never saw a bad cam.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 5.7L with a bad cam [Re: V194] #2302420
05/10/17 03:02 PM
05/10/17 03:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have torn a few apart with bad cams lately and the bottom ends and stuff look new, even the two that had 300K miles.
The 392 cam is cheaper (I paid $68 from the dealer on the last one VS $177 for the 5.7 cam) and since the vave springs break anyhow on the 5.7 it would be a good idea to upgrade to the 392 springs. You get a way better cam for next to nothing when upgrading this way. Make sure to order the 392 automatic cam if you need MDS and 392 manual trans if you do not want MDS.
Honestly I think the cam goes bad because a roller quits rolling and starts sliding so replace the bad lifter and check all the others to make sure they roll real nice and smooth or if the cost is no concern get all 16 lifters new.
Re: 5.7L with a bad cam [Re: HotRodDave] #2302488
05/10/17 05:15 PM
05/10/17 05:15 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How does the stock 5.7 tune do with a 6.4 cam? I've heard that a tune isn't necessary but really wakes them up if you get one. Noticeable power increase with a 6.4 cam?
Re: 5.7L with a bad cam [Re: V194] #2302866
05/11/17 02:56 PM
05/11/17 02:56 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
"Honestly I think the cam goes bad because a roller quits rolling and starts sliding"
The 2015 6.4 I picked up last week suffered from this, the roller on Intake No4 was stuck , wiped the cam lobe.
"How does the stock 5.7 tune do with a 6.4 cam? I've heard that a tune isn't necessary but really wakes them up if you get one. Noticeable power increase with a 6.4 cam?"
Wondering that myself.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 5.7L with a bad cam [Re: ric3xrt] #2302876
05/11/17 03:07 PM
05/11/17 03:07 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I've read it's a 50hp increase with a good custom tune in a 5.7. It sounds like HotRodDave has some first hand experience with 392 came in 5.7's so I was just wondering what his experience is and whether he got a tune
Which 6.4 did you get? An SRT or Big Gas Truck?
Re: 5.7L with a bad cam [Re: V194] #2302917
05/11/17 04:37 PM
05/11/17 04:37 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Truck,66k mile engine . Im thinking of putting the short block in my truck and put the 2014 5.7 heads and intake on it, not looking to change the"stock5.7" look of my truck but figure it's a good way to and some inches.
Re: 5.7L with a bad cam [Re: V194] #2302959
05/11/17 06:39 PM
05/11/17 06:39 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
This is my example of a bad 5.7 cam...
https://www.youtube.com/watch?v=Co_SJjfyBI8
A seized cambearing got hold of a cam-journal and ripped it loose from the cam's splined shaft.
