Re: Removing 6 oak fuel lines
[Re: mickm]
#2300408
05/06/17 11:40 PM
05/06/17 11:40 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Put a wrench on there one way or another. Even just the ends of the opening of the wrench onto the flats, laying the wrench along the fuel line tube.
Or you can jamb a screwdriver between the flat of that fitting, and whatever is so close that you can't get a wrench on.
Or grab the fitting with a pair of pliers or needlenose.
Or make a flat piece of thick sheet metal into a special wrench that'll fit around/past the stuff that's in the way.
On mine I had to do that, but it's been so long I forget what I used.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: mickm]
#2300440
05/07/17 12:16 AM
05/07/17 12:16 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
So when I turn the nut on the fuel line, the fitting at the fuel bowl is turning as well. The middle and rear carb, there is no way to get a wrench in there.
What's the trick? The next time you have it apart flare a piece of 5/16" copper tubing,cut off the flare and put it in the inlet fitting,next time one wrench will take it off.
[Re: mickm]
#2300538
05/07/17 07:09 AM
05/07/17 07:09 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Been a while since I pulled carbs from manifold, but as I recall I had same issue. Believe what I do is disconnect individual carbs at tubing junction fittings. Do not wish to risk damage to carb fitting. Was it Matco that has a special somewhat flat open end wrench that can hold this fitting while loosening the fuel line
Normally I remove carbs when taking intake off, as is easier on my back and ensuring proper intake gasket sealing when putting it back on. As it happens due to a collapsed hydraulic roller issue, intake is off now but with carbs in place. Will have a friend help me to set it on when the time comes.
[Re: mickm]
#2300551
05/07/17 08:59 AM
05/07/17 08:59 AM
Posts: 1,567 Ky
jt4406
Ky
As stated above, pulling the carbs with the lines attached would be the safest way, then remove and correct issues with fittings and lines. You may also consider replacing the two rear fuel bowl fittings with what (I believe) originally came on them. They used a smaller wrench size (5/8?)to remove the fitting. Here's a pic of mine. You may able to source a couple through Scott at http://www.harmsauto.com/contact.htmljess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#2300662
05/07/17 01:18 PM
05/07/17 01:18 PM
Posts: 4,179 California
mickm
California
As stated above, pulling the carbs with the lines attached would be the safest way, then remove and correct issues with fittings and lines. You may also consider replacing the two rear fuel bowl fittings with what (I believe) originally came on them. They used a smaller wrench size (5/8?)to remove the fitting. Here's a pic of mine. You may able to source a couple through Scott at http://www.harmsauto.com/contact.htmljess I'll check out those original fittings, but the fuel line blocks access to the rear bolt of both the middle and rear carb, so there is no taking them off with the fuel line on.
[Re: 62maxwgn]
#2300664
05/07/17 01:20 PM
05/07/17 01:20 PM
mickm
California
What's the trick? The next time you have it apart flare a piece of 5/16" copper tubing,cut off the flare and put it in the inlet fitting,next time one wrench will take it off. Can you be more specific, I'm not sure I get it...
[Re: mickm]
#2300693
05/07/17 02:20 PM
05/07/17 02:20 PM
Sxrxrnr
Northern Calyfornua
As stated above, pulling the carbs with the lines attached would be the safest way, then remove and correct issues with fittings and lines. You may also consider replacing the two rear fuel bowl fittings with what (I believe) originally came on them. They used a smaller wrench size (5/8?)to remove the fitting. Here's a pic of mine. You may able to source a couple through Scott at http://www.harmsauto.com/contact.htmljess I'll check out those original fittings, but the fuel line blocks access to the rear bolt of both the middle and rear carb, so there is no taking them off with the fuel line on. Yes, as I recall fuel line blocks access to these bolts. I know that somehow I get around this,,,perhaps a nut and stud at these positions. I will have a look see at what is done on mine and update. Your fuel lines appear same as what I have. Mickm: Wine/art festival Castro Street Mtn View today with open to all classic car show. I am on my way.
[Re: Sxrxrnr]
#2300805
05/07/17 07:12 PM
05/07/17 07:12 PM
mickm
California
Yes, as I recall fuel line blocks access to these bolts. I know that somehow I get around this,,,perhaps a nut and stud at these positions. I will have a look see at what is done on mine and update. Your fuel lines appear same as what I have. Mickm: Wine/art festival Castro Street Mtn View today with open to all classic car show. I am on my way. [/quote] I usually go down there, especially as I'm 6 blocks away! But simply forgot about it yesterday, and now the car has a carburetor off! Next time... Yes, do let me know what you did about the bolts.
[Re: mickm]
#2301289
05/08/17 06:40 PM
05/08/17 06:40 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Yes, the fuel lines of the carbs block access to the other carbs' bolts. You have to take off the "S-line" for the middle carb to get access to the pass/rear bolt of the front carb. The same holds true for the middle/back carb.
Yes, those lines are tight & easy to twist/ruin. I usually try to loosen the brass "T's" since I can get at those easier. If the carb fitting spins (if I can't get a wrench on it), I just un-hook the other end of the "s-line" at the brass fitting & take it off with the carburetor. I can't count the number of seized/twisted 6-pack S-lines I've seen.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Sxrxrnr]
#2301352
05/08/17 09:07 PM
05/08/17 09:07 PM
Sxrxrnr
Northern Calyfornua
Normally I remove carbs when taking intake off, as is easier on my back and ensuring proper intake gasket sealing when putting it back on. As it happens due to a collapsed hydraulic roller issue, intake is off now but with carbs in place. Will have a friend help me to set it on when the time comes. I had a look at my setup which has a mixture of bolts and studs. Disconnect all lines from brass junction, then as a Chinese puzzle it should be apparent the sequence required to remove each carb.
