Re: Making an internal balance flywheel work on a stock 360... [Re: dogdays] #2295928
04/29/17 04:00 AM
04/29/17 04:00 AM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
Originally Posted By dogdays
Cheapo trick from chevy racers back in the day...
Sandwich the 5.9 Mag flexplate behind the neutral balance flywheel.
Voila!
Done
Slightly more expensive: Get the 360 add-on weight and drill it to reduce the amount of imbalance. I believe with the MP drawings you can figure out what angle and how much to remove.
R.
Or one could possibly get both parts, and use the flexplate as a template/guide for modifying the smaller pie piece. Hmmm...
Either way i go, shouldn't be too hard to figure out.
Re: Making an internal balance flywheel work on a stock 360... [Re: Pale_Roader] #2296130
04/29/17 03:23 PM
04/29/17 03:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By Pale_Roader
He says "They'll work" on a Magnum 360. When i mentioned the slight balance/bobweight differences he said 'Its close enough". Says "people run it all the time".
Gosh, that's reassuring.........not.
Re: Making an internal balance flywheel work on a stock 360... [Re: John_Kunkel] #2296371
04/30/17 03:19 AM
04/30/17 03:19 AM
Swears too much
Swears too much
Well... this guy builds more HP engines in a week than i'll build my entire life... so his guess is probably worth more than my math. But yeah... there's that little instinct...
Re: Making an internal balance flywheel work on a stock 360... [Re: Pale_Roader] #2296376
04/30/17 03:27 AM
04/30/17 03:27 AM
When in doubt, do without work twocents
Don't hurt yourself trying to save money on motor, tranny or any other drive line parts tsk twocents
Re: Making an internal balance flywheel work on a stock 360... [Re: Cab_Burge] #2296383
04/30/17 05:01 AM
04/30/17 05:01 AM
Swears too much
Swears too much
Heh... what exactly do you mean by that? Cant exactly do without a proper balance now...
Re: Making an internal balance flywheel work on a stock 360... [Re: Pale_Roader] #2296972
05/01/17 05:59 AM
05/01/17 05:59 AM
Swears too much
Swears too much
Dammit! Summit doesn't carry the flywheel i want. Already making a big order from them, would have been nice to tack it on and get everything from one source. Grrr...
