9.25 swap #2296661
04/30/17 06:30 PM
04/30/17 06:30 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
If I was swap rear-ends in my 95 ram(3.55's) with a later model 1500 (3.90's)rear what years will bolt in with no fuss?.....Thaxs.
Re: 9.25 swap [Re: racerx] #2296959
05/01/17 03:02 AM
05/01/17 03:02 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
In the old days (when I worked in a wrecking yard) I would consult the Hollander interchange manual and have the answer...since that job was nearly 30 years ago all I can suggest is that probably as late as a '99 Ram 1500 (I had one) will work as they had drum brakes and I am not sure when they went to disc. But, of course, I could be wrong. So get really friendly with a wrecking yard counterman and have him help you look in his resources (probably a computer nowadays) up
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 9.25 swap [Re: Polarapete] #2301739
05/09/17 01:59 PM
05/09/17 01:59 PM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
Everything up to 01 should work. Rare to find, but a few 01 trucks got rear discs. After the new body style in 02 the widths changed. And I believe the earlier trucks 93 and under are even narrower. I have been thinking of swapping in an 01 rear end under my 92, but haven't measured it up yet. I want 3.23 gears for my diesel swap, more highway friendly.
Re: 9.25 swap [Re: Polarapete] #2304346
05/14/17 03:12 PM
05/14/17 03:12 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
More or less the same thing can be done using www.car-part.com. Put in your vehicle specifics, search for the part you have, and see what other year models pop up as interchanging in the list of available parts.
Re: 9.25 swap [Re: mgoblue9798] #2304704
05/15/17 03:47 AM
05/15/17 03:47 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Hollander parts works well also..
check local Craigslist for available parts, lots of rusted wrecked 2nd gens our there for now.
2000 and 2001 Off Road version, used 4:10 gears only, if that is closer to what you want.
Re: 9.25 swap [Re: racerx] #2304950
05/15/17 04:03 PM
05/15/17 04:03 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs for the heads-up Gents up
