So many different options on rear main seals #2295962
04/29/17 10:02 AM
04/29/17 10:02 AM
1930 Offline OP
1930  Offline OP
Getting ready to assemble a 440, want to do everything I can to not have any issues with rear main seal, I found a thread on this site where these http://www.dvorakmachine.com/rearmainseal.shtml were recommended but the thread was from 2009.
Any better suggestions?
Re: So many different options on rear main seals [Re: 1930] #2296044
04/29/17 12:54 PM
04/29/17 12:54 PM
I agree rear main leaks are the cats' ass. I would get the surfaces squeaky clean with brake kleen & some silicone under the seal halves and a drop where the seal halves meet each other & also goop the sticks on the sides before installation & you might offset the seal halves 1/4". & as you know but just a reminder, the seal lip toward the oil. You'll be fine. Others will chime in with more info.
Re: So many different options on rear main seals [Re: RapidRobert] #2296055
04/29/17 01:05 PM
04/29/17 01:05 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
This right here is where the problems start RR.... all kinds of bad info.
http://www.manciniracing.com/subheporemas.html
Re: So many different options on rear main seals [Re: roadhazard] #2296056
04/29/17 01:07 PM
04/29/17 01:07 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I don't understand your point. Please elaborate.
Re: So many different options on rear main seals [Re: 6PakBee] #2296065
04/29/17 01:23 PM
04/29/17 01:23 PM
Me too, I was wondering if my posted info was off. EDIT After rereading it sure sounds like he is saying some or all of my info is off. I can say that that plan has worked for me in the past but if something is off or borderline off let me (us) know & I have a 451 in the works & I too want it right (no leaks).
Re: So many different options on rear main seals [Re: 6PakBee] #2296071
04/29/17 01:31 PM
04/29/17 01:31 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You start putting sillycone on the rear main seal and you have already lost the battle. Never, EVER use that stuff on a rear main seal.
The very first consideration BEFORE a rear main seal goes in is dimensions of the seal groove, it must be on size and Round.
Secondly the rear seal retainer should be aligned with the groove in the block and a reference mark scribed on the pan rail surface for assembly. Alignment of the two seal halves is critical.
3rd, check the crank for dimension and surface finish. Knurling on some of the aftermarket cranks is way to aggressive from what I have seen. Never had an issue with a stock crank, knurled or not.
The point is, do your due diligence BEFORE slapping a seal in and slathering it with sillycone.
I posted a link for a seal that I have intimate knowledge on for nearly 30 years. If it leaks.... it won't be the seal.
Re: So many different options on rear main seals [Re: 1930] #2296072
04/29/17 01:32 PM
04/29/17 01:32 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Be certain if using new pan bolts from certain vendors that the 2 bolts at rear of pan into retainer, do not bottom out before pan cinches to engine thereby leaving you with a pan gasket leak at this location that may confuse you into believing that your rear main is leaking.
Re: So many different options on rear main seals [Re: Sxrxrnr] #2296076
04/29/17 01:37 PM
04/29/17 01:37 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just wondering out loud, but why doesn't someone come up with a one pice seal like we put in the nose if airplane engines. You stretch it around the flag and then glue into the case, and they don't leak.
Re: So many different options on rear main seals [Re: Sxrxrnr] #2296077
04/29/17 01:38 PM
04/29/17 01:38 PM
Alright, on my 451 I will not use silicone.
Re: So many different options on rear main seals [Re: 71birdJ68] #2296085
04/29/17 01:48 PM
04/29/17 01:48 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
My best educated guess is the flange on the back of the crank is to large compared to the seal I.D. and stretching a Polyacrylate or Fluoroelastomer (Viton) seal much if at all would prove very difficult IMO.
Not to mention the damage that can occur to the seal dragging it across the flange.
Re: So many different options on rear main seals [Re: 71birdJ68] #2296116
04/29/17 02:48 PM
04/29/17 02:48 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
They do make a one-piece seal but it's not intended to stretch over the flange although I don't see why you couldn't considering that all SAE prop flanges are larger than the Mopar.
http://www.fastfishautoparts.com/Performance-Engine-Seals.html
Re: So many different options on rear main seals [Re: John_Kunkel] #2296126
04/29/17 03:08 PM
04/29/17 03:08 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Wow! That would be worth buying just to try it. John, where do you dig this minutia up?
Re: So many different options on rear main seals [Re: roadhazard] #2296168
04/29/17 05:56 PM
04/29/17 05:56 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Airplane crank flings are much larger than car flanges. There is a special tool to stretch, and walk it on with. What we do is warm up the seal, and unhook the spring ends, then walk it over the flange. After a little while it shrinks back to size, we hook the spring back together and using contact cement push it into its place in the case. Sometime we take a razor, and slice it to get it around the flange.
Just wondering if this could be considered.
Re: So many different options on rear main seals [Re: 71birdJ68] #2297193
05/01/17 03:31 PM
05/01/17 03:31 PM
dogdays Offline
dogdays  Offline
So the airplane seal is spring loaded?
When I took apart my first engine that had a one piece rear seal I was amazed at how easy it was to use, and wondered what took American car manufacturers so long to figure it out?
I believe the one piece seal that is already on the market is intended to be cut and then glued back together, probably with a drop of Superglue.
R.
Re: So many different options on rear main seals [Re: 1930] #2297210
05/01/17 03:50 PM
05/01/17 03:50 PM
I use the stock Mopar or Fel Pro rear main seal kits with "Adhesive Sealant" type gasket maker on the front label, not any other type tsk I use a small dab on the mating ends of both seal and the seal holder and follow the directions on the instruction sheet for the side seals and then wait 24 hrs. for the mineral spirits to soak in and run off. I use a small thin bladed screw driver to use the adhesive sealant to fill and seal up the V joint between the rear main seal holder and the block flush with both sides on both sides as well as the bottom of the seal holder to the block thumbs scope
DO NOT use regular automotive silicone gasket maker for this tsk Adhesive Sealant type only!
Re: So many different options on rear main seals [Re: dogdays] #2297222
05/01/17 04:08 PM
05/01/17 04:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes, there is a small spring that goes all the way around the sealing lip on most airplane flange seals. I think it holds the lip with pressure.
