Re: Edelbrock heads and piston questions
[Re: 440mopar]
#2298393
05/03/17 04:59 PM
05/03/17 04:59 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you're dealing with an experienced "engine builder", just have him order what he needs.
[Re: fast68plymouth]
#2298426
05/03/17 06:33 PM
05/03/17 06:33 PM
dogdays
Math time: A 512 engine has 1049cc swept volume. To get to 10.5:1 compression divide swept volume by 9.5. That's 110cc. ASSUME: Piston at zero deck, 12cc head gasket, 5cc valve pockets, 84cc head = 101cc. That's going to get you 11.4:1.
You need to lose 9cc from the half of the piston not under the squish area. Let's say you use a 3.5" circle, you need a half circle 0.0115" deep. That's with all my other assumptions.
It's just math.
What I think you and your engine builder are missing is that you don't have to buy the crank, rods and pistons as a kit. If you buy the pistons separately, you can get exactly what you need. Buying a piston with too large a dish and then milling a brand new head to get the compression ratio you need is IMHO pretty dumb. Hogging out the combustion chambers to 93cc is also dumb, that's quite a bit of aluminum and you don't want to lose the squish pad area. So that makes the amount taken out of half the chamber pretty big.
R.
[Re: Jeremiah]
#2298979
05/04/17 04:28 PM
05/04/17 04:28 PM
dogdays
