AMD Big Block Valve Covers ?
#2295647
04/28/17 03:11 PM
04/28/17 03:11 PM
Posts: 3,821 New State
kidmopar
New State
Hello All ! ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif) Just purchased a set of the AMD 1971 Big Block Steel ( Zinc ? ) Valve Covers . Couple questions please ............ 1) Should I "Prime" them PRIOR to painting Orange ? ( If so ... What primer ? ) 2) BEST Orange paint ? ( Mopar Paint ? VHT ? or "?" ..... ) Thank You All for any / All Professional advice ! ![coffee coffee](/ubbthreads/images/graemlins/custom/coffeetime.gif)
Re: AMD Big Block Valve Covers ?
[Re: BlueRacer69]
#2295726
04/28/17 06:57 PM
04/28/17 06:57 PM
kidmopar
New State
I just got a set of them last week myself. I going to primer mine with high temp (500 degree) ceramic primer, then shoot them with Mopar engine paint (street hemi orange). I've always had good luck with the Mopar brand engine paint, but it all begins with how you prep the item first before primer & paint. I was kinda thinking same thing ..... May I ask what brand primer you're going to use ? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: kidmopar]
#2295796
04/28/17 09:42 PM
04/28/17 09:42 PM
Posts: 737 Michigan
BlueRacer69
I just got a set of them last week myself. I going to primer mine with high temp (500 degree) ceramic primer, then shoot them with Mopar engine paint (street hemi orange). I've always had good luck with the Mopar brand engine paint, but it all begins with how you prep the item first before primer & paint. I was kinda thinking same thing ..... May I ask what brand primer you're going to use ? I'm going to use Dupli-Color high heat ceramic gray primer, good to 500 degrees. Think I got it a Napa. Make sure you fellow the directions on the back of the can. Also clean your valve covers well with something like CRC's Breakleen or even paint thinner before you prime.
[Re: parksr5]
#2296301
04/29/17 11:37 PM
04/29/17 11:37 PM
kidmopar
New State
Just another real world experience; my original valve covers were blasted and in etch primer when I received them. From there, I had a small dent in one of them. I actually used filler on the dent and used RM filler primer that you would use on body panels, block sanded them and then shot them with Mopar rattle can. They've been done for around 4-5 years and I've had no issues; the combo has been very durable. THANK YOU ! ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif) Appreciate your input ! Seeing as that these are "New" and look pretty nice 'Out of the Box' I believe I'm going to go with just the primer then 'Rattle Can' with the Mopar 'Hemi Orange paint ...... I ordered some primer & paint and will let you know how they come out in a week or so ..... ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
[Re: shakerjoe]
#2296493
04/30/17 01:28 PM
04/30/17 01:28 PM
kidmopar
New State
Are you positive they're '71's? I ordered a set from Summit and they were '70s in 71 boxes...returned to Summit no problem, but they were AMDs... Yes , Received them from Stephen's Performance Part Number 335-1071 ( R&L )
[Re: shakerjoe]
#2296623
04/30/17 05:08 PM
04/30/17 05:08 PM
kidmopar
New State
Yes , those appear to be 1970 covers as mine have the "bump" on the PCV valve side cover which is for 1971 ? My 1971 Challenger R/T has several pieces ( Console for one ) that are 1970 as the car was built in September / 1970 ........ After looking AGAIN ..... Looks like you have one 1970 & one 1971 ?????
[Re: kidmopar]
#2296805
04/30/17 10:13 PM
04/30/17 10:13 PM
Posts: 566 WA
tman
WA
I bought the 70 VC July 2015. My gaskets fit perfectly. I would return them if they are not spot on, so don't paint them. Also the holes on mine were NOT elongated. Wonder if those were early ones where your holes are half off? I got mine from Summit. I would return them if gaskets do not line up. The only issue I had was with one valve cover with the bendable wire retainers. They were all missing on mine. Summit took them back and paid for shipping. Ordered another pair and everything was good.
[Re: 6bblgt]
#2296866
04/30/17 11:23 PM
04/30/17 11:23 PM
Posts: 3,003 Long Island, NY
shakerjoe
Long Island, NY
how old are those valve covers?
is this AMD's solution for the early mis-aligned bolt holes, how big are those holes?
Just checked my receipt, I ordered them 05/11/16 fwiw
[Re: shakerjoe]
#2296914
05/01/17 12:28 AM
05/01/17 12:28 AM
Posts: 737 Michigan
BlueRacer69
Just checked my receipt, I ordered them 05/11/16 fwiw I just got mine a week ago 4/21/17. No oblong bolt holes but the holes are off a bit, about half a hole when match up to my valve cover gaskets from Real Gasket company. Have not tried fitting them to the head itself yet. Also when you put a valve cover bolt in a hole the washer under the head of the bolt makes contact with the side of the cover just slightly.
