Ring seating problem...i think
#2295259
04/27/17 09:05 PM
04/27/17 09:05 PM
Posts: 19 Ca
67valentine
Ca
OK...built myself a 472 hemi motor a couple years back using chrome JE piston rings. I've had a problem consuming oil from the beginning...like a quart within a few hundred miles...also noticing that the oil turns black almost immediately. Looks like the tops of all of the pistons are wet (oil) and the spark plugs are also generally wet looking. I get smoke on decel primarily and on hard acel. It seems that ive got oil in the chamber..think ive ruled out valve stem seals (brand new) or head gasket. I still need to do a leak down again, but I'm leaning toward rings. The motor now as about 2000-3000 miles on it so the rings should be seated.
My suspicion is this and wondering if anyone can comment: This motor never gets very hot...even on the hottest days, idling for long periods in traffic, the temp gauge rarely reads above the normal marks on the temp gauge. The radiator is a factory 26", but I added a 4th row for better cooling. I'm wondering if by adding the 4th row, the motor is not getting very hot, possibly preventing already difficult to seat chrome rings to never really seat? I've been advised to try the borax soap method into the carbs as an old school way of roughening up the cylinder walls and encourage the rings to seat...im willing to try about anything to prevent taking the motor apart.
Any expert opinions on what I've described? thanks...
Re: Ring seating problem...i think
[Re: 67valentine]
#2295271
04/27/17 09:31 PM
04/27/17 09:31 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
if you put a 190 degree thermastat in it, it will get up to that temp. [ they can stick open] the chrome rings can be very tough to seat... even moly rings need a proper hone job to seat quickly . what oil did you use to break it in? probly best to put a moly set in it and rehone... there are a pile of tricks from the past to attempt to seat them but I would bite the bullet on the rings if the leakdown test confirms it.
[Re: 67valentine]
#2295332
04/27/17 11:08 PM
04/27/17 11:08 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
the temperature needs to be verified by a known accurate method, IE: thermocouple probe works best with a digital meter. I would doubt it has much to do with oil comsumption. Oil Consumption can be due to, valve guides, seals, intake gaskets/ port mismatch, cylinder wall surface or the oil control rings themselves.
[Re: 67valentine]
#2295343
04/27/17 11:19 PM
04/27/17 11:19 PM
Posts: 4,462 Morristown Tn.
71birdJ68
Morristown Tn.
It's really hard to get the intake gaskets from letting oil by. Turn it until the intake valve is open, and see if there is a large build up of sluge on the valve, that would indicate the gasket or valve seal, and guide. If you only use a qt in a few hundred miles, that a lot better than some of us.
[Re: stumpy]
#2297373
05/01/17 08:38 PM
05/01/17 08:38 PM
RapidRobert
The jist of that mototune article is that you get one & only one immediate shot on breakin to get a good ring seal & the throttle needs to be goosed repeatedly to load em. I would go with some file fit plasma moly rings & a 320 grit BRM dingle berry hone & use the BRM procedure. BRM wants people to bore to size/no rigid hone then hone with their tool. I disagree & say bore/rigid hone then dingle berry but you are already there so that part (right or wrong) is a non issue. the rest of their info is good (drill speed/# of strokes etc). EDIT 320 grit silicon carbide
