Re: 727 parts shopping
[Re: mopar dave]
#2293876
04/25/17 02:50 PM
04/25/17 02:50 PM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
yes, there has been two members here that claimed they lost 1/4 mile ET using the steel billet drum. I have a personal friend who has a 68 dart with a 440SB using w7 heads. dyno'd 716hp. I can beat him to the 1/8 strip with my 408 in my barracuda. His car does not get out there like it should. He uses a billet front drum. I believe that drum is heavier than the stock drum. I would think it would take more time to stop that drum on the shift. I can tell you I went from a basically stock 727 with just good usual parts, to a roller 727 with aluminum drum and on consecutive weekends with the same air saw zero difference. Don't think the drum, no matter what type you use is gonna make a worthwhile difference. Even if it was 2 hundreds, get what is easy to find.
[Re: mopar dave]
#2293918
04/25/17 03:41 PM
04/25/17 03:41 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
Silver67...you'll definitely to get steel planetaries. Mine has a 5 pinion steel setup. The stock aluminum ones will strip the splines.
Mine still has stock input and output shafts in it. It wouldn't surprise me if one or the other broke at any time though.
[Re: Scamp408]
#2294371
04/26/17 09:47 AM
04/26/17 09:47 AM
Posts: 9,863 MI, usa
dvw
MI, usa
At what point do you need the 300m shafts We've run 9.0@3350lbs foot brake (400runs) and 9.5@3750lbs w/trans brake. Both cars have stock input and output. The foot brake car got around 250 passes on the stock planet carrier before it started to twist the splines. It did not completely fail, caught it during maintenance. The trans brake car did strip the stocK front planet splines. Doug
