Got my 10.50s pass ,
#2292343
04/22/17 08:58 PM
04/22/17 08:58 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
Finally went 10.50s yesterday at local championship round . DA was around 13/1400 from 1/4s Went 10.572 on brake , 10.584 on brake then broke out in final with a 10,538@120.96 on the brake . We both had crap lights my worst had been 0.77 until then Had some Viking Crusader AM shocks really changed how the satellite launched , drove out of the hole instead of snatching the front up . Finally got a good sixty Thanks again for all the help
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Got my 10.50s pass ,
[Re: tex013]
#2292562
04/23/17 06:00 AM
04/23/17 06:00 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Decent 60 ft for a big car. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#2292570
04/23/17 08:44 AM
04/23/17 08:44 AM
tex013
Sydney,Australia
Decent 60 ft for a big car. Mick Thanks Mick . Funny enough all previous 7 passes were 1.485 to 1.5 sixty though i expected to run 1.45/6range to get the et.So not sure why the big gain . But i won't complain Sgcuda , my goal was a 10.5 something , others talked up a bigger et . See how it goes next month , as the air cools off and goes dryer. I guess i still have the dominator to try Hell i love running fast but that sandtrap is getting closer Here ks 1st pass with the Viking shocks https://youtu.be/ep6YnvDe_aMTex
[Re: tex013]
#2292890
04/23/17 07:51 PM
04/23/17 07:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Congrats.. what did your plugs tell you.. are you just now coming into the proper conditions for your set up
[Re: MR_P_BODY]
#2293069
04/24/17 02:39 AM
04/24/17 02:39 AM
tex013
Sydney,Australia
Congrats.. what did your plugs tell you.. are you just now coming into the proper conditions for your set up No plug pull , the air was a lttle better than when I chassis dynoed it . So potentially coming closer into its tune up . Still not sure big 60foot pickup Tex
[Re: tex013]
#2293073
04/24/17 02:55 AM
04/24/17 02:55 AM
MR_P_BODY
Congrats.. what did your plugs tell you.. are you just now coming into the proper conditions for your set up No plug pull , the air was a lttle better than when I chassis dynoed it . So potentially coming closer into its tune up . Still not sure big 60foot pickup Tex What were your other 60' that day.. were they in line with that one.. or was that a odd one.. its nice to see a GOOD one but not if its a odd ball.. I look at the odd ball ones more than I do the normal ones to see WHY EDIT If you wheel stand like I do that can be a factor.. on a good weather day I can get a slow 60'.. I have found via video that the rear wheels are what clicked the 60' lights..and not the fronts but it does catch my attention
[Re: tex013]
#2293075
04/24/17 03:00 AM
04/24/17 03:00 AM
tex013
Sydney,Australia
no relation to earlier . They went - 1.493,1.49,1.486,1.501,1.485,1.483,1.485 then 1.456 . Only thing different there was a 30-45 wait whilst a ambulance took a rider for observation . They were dragging the track during this down time but seemed mostly top end where accident occurred .
Tex
[Re: tex013]
#2293150
04/24/17 11:24 AM
04/24/17 11:24 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: tex013]
#2293713
04/25/17 09:35 AM
04/25/17 09:35 AM
deaks
robin hood country
I went to a track over here, ran 1.47 60 fts and up, one run they prepped the track for a supercharged alcohol car, i ran after did a best ever 1.36 60ft. Mick
[Re: tex013]
#2293763
04/25/17 11:39 AM
04/25/17 11:39 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
The Vikings are on the rear? which model? What are you running up front?
I was struggling the end of last year to hook, but I am running 90/10's up front and rancho's in the rear full tight. My front rises very quick, but i could probably use more control in the rear too.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
