Dana 60 axle seal size question... #2292738
04/23/17 02:49 PM
04/23/17 02:49 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
I have a 1969 Dana 60 out of Dodge Charger. I am trying to identify and purchase the correct axle seals (inner that press into the housing).
From doing some reading it says some seals fit both 8 3/4 and Dana. I have a set of extra axle seals on the shelf for a 8 3/4 but the outer diameter is a bit too big to fit into the Dana housing. I don't have the original Dana 60 seals that came out to reference a part number.
Anyone happen to know of a make and part number that would possibly fit?
Thanks, Wolf.
Re: Dana 60 axle seal size question... [Re: Wolfe440] #2292764
04/23/17 03:41 PM
04/23/17 03:41 PM
Mass
charge70 Offline
charge70  Offline
Mass
Wolfe,Dana 60 seals are different than 8 3/4.The mopar part # for the Dana is 2852574.You will need to cross this to a national seal #. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Dana 60 axle seal size question... [Re: charge70] #2292770
04/23/17 03:46 PM
04/23/17 03:46 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
Ok, thank you! Wolf.
Re: Dana 60 axle seal size question... [Re: Wolfe440] #2293103
04/24/17 08:54 AM
04/24/17 08:54 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Hope this helps. You have to look up something silly to find it but this is the one.
DD
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: Dana 60 axle seal size question... [Re: Big D A12] #2293270
04/24/17 03:40 PM
04/24/17 03:40 PM
Canada
RobR Offline
RobR  Offline
Canada
The national seals I sold for pass car Dana's were the 481837and 8 3/4 used the 8695..
The 51098 to my memory is a ford seal
Re: Dana 60 axle seal size question... [Re: RobR] #2294351
04/26/17 08:25 AM
04/26/17 08:25 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Exactly, that is the silly part. It is the seal you want.
Re: Dana 60 axle seal size question... [Re: Wolfe440] #2294562
04/26/17 04:40 PM
04/26/17 04:40 PM
Canada
RobR Offline
RobR  Offline
Canada
I would be careful using that ford 51098 seal,as it is a thicker body and the A7 bearing retainer "will/could touch" that seal and concave the seal ...and could cause that type of seal to leak..IMHO
but if you've used it and not had a problem all the power to ya...plus its a bunch Cheaper than the 481837 Nat seal.:)
Rob
Re: Dana 60 axle seal size question... [Re: RobR] #2294972
04/27/17 12:58 PM
04/27/17 12:58 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
These guys are right, I ran into this myself a few years ago, here's a shortened down version of what I did.....
Thanks Dr. Diff!!
I checked at the local Napa for the 67 Ford 1/2 ton pickup with 9.75 dana. The seals listed for it fit!
They are Napa part # 15142 for those of you who may need them. They are a little smaller than the ones the parts book listed that wouldn't fit, just like the doc said.
Also, some more info for you guys doing your own boogie with a dana 60. I needed a "speedy sleeve" for the yoke (a sleeve that fits over the groove worn in the yoke by the seal and 30 plus years of use). All three parts stores in town listed the sleeve, no one had it in stock, but were glad to order it for me, at the cost of around $25-$30 bucks. I asked a lifelong parts man about a sleeve, he looked at it, says "I think I have what you need" (didn't look it up) walked back up from the back with Carquest # A226-2 sleeve, fit perfect, $6 bucks!!
One last thing, Dr. Diff, the axle bearing locking collar is still available by itself, Timken # K108601 (from A&W Bearing in Texas).
Thanks for the help guys.
jt
You can read the whole thread here...https://board.moparts.org/ubbthreads/ubbthreads.php/topics/12625/re-dana-60-axle-seal-question-update.html#Post12625
hope this helps
jess
Yeah, it's hopped up to over 160...
