Any guesses on a stall change and low gearset
#2287952
04/14/17 11:30 PM
04/14/17 11:30 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I sent my old 5180 stall converter to Transmission Specialties to have it upped to 5700-5800 stall today. I will also be changing my stock 1.76 low-gearset to a 1.98 straight-cut low gear in my powerglide. My 422 small block went 6.00@113.27 and 9.56@137.89 with a 1.32-1.34 60 foot with the 5300 stall converter that is in it now. Any guesses on how she will run when I switch it out in a few weeks. It feels like a snail leaving the line right now.
Re: Any guesses on a stall change and low gearset
[Re: pittsburghracer]
#2288295
04/15/17 04:23 PM
04/15/17 04:23 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
No guesses so far. I'm going to guess .12 pickup in the 1/4 mile with the solid lift cam that is in the engine now. Of coarse I would be VERY happy to see more.
#2288374
04/15/17 07:09 PM
04/15/17 07:09 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What does the car weigh ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#2288379
04/15/17 07:16 PM
04/15/17 07:16 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What does the car weigh ? It's around 2750 now up from 2575 or so. I'm over 100 pounds heavier than my son that used to drive the car and I sold the fiberglass doors and went back to steel doors with wind up windows. Also added a few pounds with some other user friendly items
#2288846
04/16/17 02:37 PM
04/16/17 02:37 PM
Posts: 4,210 New York
polyspheric
New York
I'm not qualified to make a guess at your question, but your new low gear will reduce your stall speed slightly.
Boffin Emeritus
#2288875
04/16/17 03:32 PM
04/16/17 03:32 PM
Posts: 76 georgia
intenseneon
georgia
No guesses here but am interested to see how much your combo picks up with the gearset change. Keep us updated. I'm considering changing out the 176 gear in my glide to the 198.
69 Dart
[Re: polyspheric]
#2288878
04/16/17 03:47 PM
04/16/17 03:47 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm not qualified to make a guess at your question, but your new low gear will reduce your stall speed slightly. Transmission Specialties will have my convertor on Monday and cut it apart. They usually call the next day to discuss changes but he already said I was going in the right direction bumping it up to the 5700-5800 area. When I tell him about the gear change we shall see if that factors in.
[Re: intenseneon]
#2288880
04/16/17 03:48 PM
04/16/17 03:48 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
No guesses here but am interested to see how much your combo picks up with the gearset change. Keep us updated. I'm considering changing out the 176 gear in my glide to the 198. Will do but it will be several weeks.
#2288894
04/16/17 04:20 PM
04/16/17 04:20 PM
Posts: 20,205 Park Forest, IL
slantzilla
Park Forest, IL
Will the extra converter stall keep it from lugging the motor on the gear change?
We tried low gear sets with our little tiny motors and what we gained with a low gear set we gave back at the shift.
[Re: slantzilla]
#2288923
04/16/17 04:57 PM
04/16/17 04:57 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We tried low gear sets with our little tiny motors and what we gained with a low gear set we gave back at the shift. The big thing to remember here is us powerglide guys are really geared high. A 1.98 gear is still way high compared to a 3 speed. Years ago I tried a stock 1.82 powerglide gear behind one of my 440 engines and it was .08-.10 quicker. They are lighter and it only last 125 passes before I broke it. Never broke a set of 1.76 gears.
#2289218
04/17/17 02:16 AM
04/17/17 02:16 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
When I ran S/ST in my Challenger with a mild 440, I started out with a 1.96 low gear set in my Glide, and absolutely loved it. It broke after 275 runs, so I bought a 1.76. Rear Gear, and converter changes never gave me back the 60ft. I lost from that change, just never could compensate for it.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: 10sec.dart]
#2289646
04/17/17 08:34 PM
04/17/17 08:34 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm curious to see what my car picks up this year,78 Plymouth arrow tube chassis car, 2560 with me in it, went 9.79 with a cheap 10" 4000 stall converter in my 904, put a ultimate 5500 stall 8" in this winter, so we will see in a couple weeks... I think you will love the results
[Re: 10sec.dart]
#2289657
04/17/17 08:51 PM
04/17/17 08:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm curious to see what my car picks up this year,78 Plymouth arrow tube chassis car, 2560 with me in it, went 9.79 with a cheap 10" 4000 stall converter in my 904, put a ultimate 5500 stall 8" in this winter, so we will see in a couple weeks... Any clue to how much power you make.. but at your weight you should be easy is the 9.30s unless you have a big anchor in the car
[Re: 10sec.dart]
#2289810
04/18/17 12:21 AM
04/18/17 12:21 AM
MR_P_BODY
I don't have any idea, The motor is a stock stroke 360, eddy heads ported by shady dell, ported victor 340 intake, custom racetec pop ups, I got 240 psi this last fall with the cylinder pressure gauge! 1050 dom running e98. 1 7/8 to 2" fender exit headers I built. Never have had a good converter in the car, the vert I put it in came out of my 70 dart with iron headed 360. so it wasn't anywhere close to what the Arrow is for weight or chassis. best 60 foot I ever got was a 1.32, no matter the up grades I did to the motor the 60 would pretty much stay the same. With the 1.32 your not way off.. if you have good parts i the engine you should e turning 8000 to 8500 rpm.. you have good cyl pressure.. do you know what the heads and the intake flow
[Re: 10sec.dart]
#2289938
04/18/17 10:58 AM
04/18/17 10:58 AM
MR_P_BODY
The heads flow 290 at .600, not sure what the intake flows, shifting at 7000 right now crossing at 7300 ish, solid flat tappet cam, 642 on intake 652 on exh. 292 duration, I only had Ryan do a stage 2 on the heads, What does your conv stall at now.. I think you said its a trans brake now.. pull the chip on the revs ans see what your max stall is now
[Re: MR_P_BODY]
#2290068
04/18/17 02:57 PM
04/18/17 02:57 PM
Posts: 72 sioux falls, sd
10sec.dart
sioux falls, sd
Yea it's a transbreak, the old one was 4000, I haven't pulled the pill and checked the new one yet, Lenny from ultamate set the new one up for 5500, the old converter was out of round and was a basket case, locator snout would bottom out in the crank before the flex plate would mate up to the bolt holes, it was a 10" to and my new one is a 8", I honestly don't care if it runs exactly the same, but picking up a little et is always fun.
[Re: 10sec.dart]
#2290084
04/18/17 03:26 PM
04/18/17 03:26 PM
MR_P_BODY
Yea it's a transbreak, the old one was 4000, I haven't pulled the pill and checked the new one yet, Lenny from ultamate set the new one up for 5500, the old converter was out of round and was a basket case, locator snout would bottom out in the crank before the flex plate would mate up to the bolt holes, it was a 10" to and my new one is a 8", I honestly don't care if it runs exactly the same, but picking up a little et is always fun. Lenny did my 8".. it was a 5000 stall but this is for my Rampage(street rod) so I asked if he could tighten it up to help the slippage.. this is on a 518 trans so it has OD.. from what he said it should be 4500-4700 and less slippage so I'm good with that
[Re: MR_P_BODY]
#2290489
04/19/17 11:03 AM
04/19/17 11:03 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
OK I shipped this thing late last week and they ripped it open and all is well and he thought the same thing as far as stall jumping up from 5150-518 to 5800 since I upped the shift point to in the 7000 rpm neighborhood. Should be finished and shipped back to me tomorrow (Thursday). Can't wait to get a no adder small block in the 5's in the 1/8 and reach for more later on with a roller cam and more head flow.
