Idler arm T/A #228761
02/18/09 01:33 PM
02/18/09 01:33 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
I put a T/A steering box in my 71 cuda, with the correct pitman arm- Is the Idler arm different as well? I have never heard that- but looks like it would turn faster one way- the way it is now? Any suppliers?
Re: Idler arm T/A [Re: Kirby] #228762
02/18/09 02:31 PM
02/18/09 02:31 PM
Kirby-Yes the arm is different.It will say fast ratio actually cast into the arm.One of the steering gear places repops them or if you need an original,I have a NOS one.PM me if interested.Sorry for the confusion,I was thinking of the pitman arm.As far as I know,the idler arm is the same.
Re: Idler arm T/A #228763
02/18/09 06:31 PM
02/18/09 06:31 PM
The linkage will look uneven with the fast ratio pitman arm installed.I think the pitman arm is actually origianally a C body arm that they "adapted" at the last minute to work with the fast ratio steering box.The result,a crooked looking steering linkage that does steer correctly.
Re: Idler arm T/A #228764
02/18/09 09:00 PM
02/18/09 09:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Umm...Actually No... The steering isn't right it has a disimilar Ackerman angle from lock to lock...The factory let it go that way figyring no one would notice/complain... The aftermarket suppliers were selling a C body idler arm & calling it a T/A arm...
