Re: At risk of being retarded
[Re: MR_P_BODY]
#228560
02/18/09 12:09 PM
02/18/09 12:09 PM
Posts: 4,213 New York
polyspheric
New York
Typo? Intake valve closes sooner.
Boffin Emeritus
[Re: polyspheric]
#228562
02/18/09 03:57 PM
02/18/09 03:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Sorry about that... I just seen it... thanks for the catch ![](/ubbthreads/images/graemlins/wave.gif)
[Re: hemi471]
#228565
02/18/09 07:15 PM
02/18/09 07:15 PM
Posts: 28,621 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Also alot of cams are ground 4 deg advanced, so when you install it straight up its advanced 4 deg. I called Comp Cams and found this,at least on the one they sold me.
both my engle cams soild and hdy were ground 4 degree advanced.
[Re: rowin4]
#228567
02/18/09 10:18 PM
02/18/09 10:18 PM
MR_P_BODY
Yes alot/most cams have 4 degrees of advance ground into them, I still advance them another 4 to 6 degrees on top of what they say for the installed degrees, specially on small blocks that need the added torque ![](/ubbthreads/images/graemlins/wave.gif)
[Re: RAT PATROL]
#228569
02/19/09 11:55 AM
02/19/09 11:55 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Cam setting is based on the overall combo.From the engine build to drivetrain gearing,chassis and desired power range,using weight,HP&torque,gearing,tire size,shift rpm,trap rpm and calculated MPH.Other reasons maybe for piston to valve clearence and cylinder volume pressures.That a cam should be advanced or retarded,you must analyze your complete combo and calculate where your power and torque curve will best benifit your antisipated performance. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: emarine01]
#228571
02/19/09 06:11 PM
02/19/09 06:11 PM
Posts: 1,200 UK
602heavy
UK
Advancing the ICL will fool the motor into thinking it has a smaller cam , considering most cams have more duration than necasary (big is not always better) , then in most appliications advancing the ICL will yield more power as the motor will build more cylinder pressure.
I advanced the ICL 8* (108 lobe sep)& went from a 1.6 to a 1.5 60ft , fitted another cam (112 lobe sep) on the assumption the 108 lobe sep was dumping most of the nitrous out the tailpipes @ overlap , picked up another 2/10ths & got me into the 10s.
[Re: 602heavy]
#228572
02/19/09 08:04 PM
02/19/09 08:04 PM
Posts: 3,695 nc
emarine01
nc
Thanks for the info, trying to get a good grasp on valve timing for my rig, I have been running 2 cams small and large and trying to figure it out by seat of the pants, Seems a lot of guys are running wide lsa with a lot of advance , still trying to get a feel for cyl preassure,lsa & advance, the simple thing is go with a 108lsa on 104 lots of cams built that way but not looking for much power under 5000, still dont know if 108 lsa in on 108 or 110 on 106 , which one is better for me? Sorry if I stomped on someones thread but the questions are closely related
[Re: emarine01]
#228573
02/19/09 09:05 PM
02/19/09 09:05 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Just a quick explanation of camshaft lobe separation, The tighter the lobe separation, the more peak torque you will have for a camshaft with otherwise all other specifications identical. For example, say you have a basic cam, 230 @ .050" and .500" lift with 1.5 ratio rockers. If this cam were ground on a 114 lobe separation angle, you would have a relatively flat torque curve with good vacuum and idle behavior due to minimal intake and exhaust valve overlap. Now take the same cam and tighten the LSA to 112*, the torque curve has become somewhat hill shaped compared to before, with a higher peak torque but it drops off quicker as the rpms increase there is a slight lope to the idle. Take it to 110* and now it's getting peaky and higher torque with a definite drop off not far past peak torque, a very noticable lope and idle vacuum is falling. Now we go to 108* and the graph now looks like a mountain with torque climbing to a large peak fast but falling off fast as well, choppy idle from excessive overlap and we are needing to up the idle rpms to keep it running in gear with a stock converter. This is due to closing the intake valve earlier and earlier as the lobes get closer together, this increases overlap so idle vacuum goes down but midrange power skyrockets. To compensate for losing power in the higher rpm range, we just increase duration to keep the valves open longer. so you have to decide on an engine compromise between manners and barbarism. ![](/ubbthreads/images/graemlins/smile.gif) This is a very basic explanation and wider lobe separation does have its place in performance, it's all in the application and what you are trying to do, but just remember the rule of thumb is the wider the lobe separation, the flatter the torque curve across the rpm range, so if you want a flat torque curve but also alot of torque then you must raise the cylinder pressure either with compression or forced induction or nitrous.
[Re: moparmanjames]
#228574
02/19/09 09:32 PM
02/19/09 09:32 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I have always installed my solid cams a couple degrees advanced with great results. My new short block came with a roller cam by CamMotion, I called CamMotion and he said my 705/661 281/283 cam is on a 104, he had me degree it in at 106 as he thought 104 with my 500" 440-1 headed combo would be all bottom end and less top end so I put it in at 106, especially since I'm running a true 10.5" tire. We'll see how it goes. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: moparmanjames]
#228575
02/19/09 09:48 PM
02/19/09 09:48 PM
Posts: 3,695 nc
emarine01
nc
Nice post, thanks- My goal is to carry as much torque to 7k as possible with 12 to 1 comp my comp solid roller 260@.05 106 on 106 is a little too peekey , good @ 55 to 6k but falls flat by 6500 with big mud tires , the 280@ .050 107 0n 103 doesent have enough @ 5500 I think its too much duration for 12 to 1 trying to pick a cam in between around 268@.050 but cant get a grasp on lsa the 108 will still be peekey I think so I was looking at 110 and advanving it 4?
[Re: emarine01]
#228576
02/19/09 10:52 PM
02/19/09 10:52 PM
Posts: 1,200 UK
602heavy
UK
A cam ground with a 110 lobe seperation angle will in most cases be installed 4* advanced , this puts the intake centre line @ 106* & the exhaust centre line @ 114* , some say the reason for this is to allow for chain stretch ![](/ubbthreads/images/graemlins/whistling.gif) , the cam card will say @ what CL the cam should be installed (if 112 lsa then they want it installed @ 108), is this what you're asking?
[Re: emarine01]
#228577
02/19/09 11:58 PM
02/19/09 11:58 PM
moparmanjames
Las Vegas NV
Nice post, thanks- My goal is to carry as much torque to 7k as possible with 12 to 1 comp my comp solid roller [Email]260@.05[/Email] 106 on 106 is a little too peekey , good @ 55 to 6k but falls flat by 6500 with big mud tires , the 280@ .050 107 0n 103 doesent have enough @ 5500 I think its too much duration for 12 to 1 trying to pick a cam in between around [Email]268@.050[/Email] but cant get a grasp on lsa the 108 will still be peekey I think so I was looking at 110 and advanving it 4?
So first, you say you want to carry as much torque to 7000 as you can, so does this mean you want your HP to peak at 7000 or do you want to shift at 7000? I think you are on the right track with the 110-112 lsa with 270* or so @ .050". If you can give me a run down of your engine I will throw it on my dyno program and see which cam will be best.
