Budget Small Block Build Ideas
#228450
02/18/09 02:28 AM
02/18/09 02:28 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a buddy who wants to build a mostly stock appearing small block for his A-body street driver. It's a mostly original 340 car and wants it to keep it's stock appearances and have about 425 HP, pump gas, hyd cam. He's not ultra cheap so no need to limit it to stock internals like rods, crank, etc. just trying to keep things under control as it's just going to be a cruiser/driver that he romps on occasionally. Car is a 4 speed, currently has 3.55 gears, and running stock 14 Rallye wheels with T/A radials. Here are the parts available, any or none of them can be used, it's just what's on hand: 1971 360, J heads, complete torn down core in good shape, standard bore with lots of miles. 1971 340, J heads, complete torn down core in good shape, .020 over and will probably need a clean up. 1970 340, standard bore, ready for a bore job, bare block 1983 318, standard bore, complete, stock, good core, steel crank. Lets here your build ideas!
Re: Budget Small Block Build Ideas
[Re: ScottSmith_Harms]
#228451
02/18/09 03:35 AM
02/18/09 03:35 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
What cid? Stroker is easy way to get there, and will work good with those gears. Just the scat 9000 crank, scat rods, and KB hypers will do the trick. Cam would be Comp's hi-lift cam, xe285hl. Do decent work to the heads, and an rpm intake with a 950HP on top and it should clear 425 by maybe another 25HP! Brian
Brian Hafliger
[Re: emarine01]
#228455
02/18/09 11:33 AM
02/18/09 11:33 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'd build the 360 with 10.25:1, and a Crane 694561. The hedas will need a good 5 angle valve job, ad I'd do a gasket match and a bowl blending, set the chambers to 68ccs. Should make very close to 425hp with serious torque. I dont think it would cost more than $5K soup to nutz depensing on what he needs.
[Re: justinp61]
#228458
02/18/09 12:15 PM
02/18/09 12:15 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
A mostly street car with 3.55's?? I'd be looking at a 4" crank for sure.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
#228462
02/18/09 01:36 PM
02/18/09 01:36 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Just some parts I have been collecting. 360 block, ported MP swirl port heads, KB pistons. stock crank or 4" (easier with a 4") weiand or ported stock intake.(cheaper and easier with the weiand), thermoquad.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
#228463
02/18/09 01:37 PM
02/18/09 01:37 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
here's what I'd do:
short block:
360 w/stock crank& rods (resized with ARP bolts), KB107's at 0 deck, new oil pump & balancer
heads: I'd probably bite the bullet, get some EQ318B's set up with 2.02/1.6 SBC +.1" valves, good 5 angle VJ, some bowl blending and open up the pushrod pinch some. this would yield 10.6:1 or so on the above short block
alternate: same valve job work done to whatever LA heads he has with 2.02 valves in them already, maybe shave them a few thou.
intake: eddie RPM w/ the edelbrock logo ground off
exhaust: headers
cam: I'd probably look at a comp XE274 or so if running mag 1.6 rockers. XE275HL if running 1.5 rockers.
even with the cost of the new heads, I don't see where it'd cost much more than $3500 to do something like this, and should be in the 420HP/440tq range easily....
#228465
02/18/09 04:01 PM
02/18/09 04:01 PM
patrick
Grand Haven, MI
dish or flat top?
Keith Black, Diamond, Ross, JE, Wiseco all make shelf pistons in both styles for that app...
[Re: patrick]
#228466
02/18/09 04:49 PM
02/18/09 04:49 PM
Triple Threat
Renton Washington
I'd use the 340, the 360 would work too, just a matter of what parts he can get deals on. Lots of cranks and other parts out there for sale right now. 340 .030 over 4" stroke = 416cid 360 .030 over 4" stroke = 408cid figure 10:1 Air gap intake 750 holley hydraulic cam in the neighborhood of .550 lift and 240@.050I wouldn't use the old iron head 425 hp or just over 1 hp/cid is easy with todays parts. You probably could choke the motor off with the old iron heads and still make 425.
#228469
02/18/09 05:29 PM
02/18/09 05:29 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Who makes an off the shelf .030 340 or 360 forged stroker piston for a 4.0 crank?
If it was me, i would buy the forged/diamond piston 4 inch kit from Mancini(balanced)and put it in the 340 block at 30 over for 416 inches.
With a set of edelbrocks mildly massaged, and a 245ish/570ish lift cam. Add an excellerator intake, a 950 carb and a decent set of headers, the car should make 470-480ish horsepower, and be extremely docile on the road.
Its just me, but i would never scrimp on internals. That Mancini kit has Callies crank, Eagle H beam rods, and diamond forged pistons..in short, light and bulletproof, and very resonable.
