Bench Seat Adjustment Wire #228446
02/18/09 01:39 AM
02/18/09 01:39 AM
Massachusetts
LYNCHROAD69.5 Offline OP
Massachusetts
When I removed my bench seat I noticed the wire that runs between the bench seat adjustment levers on the seat tracks was loose and just hanging in space. Should the wire be supported by something attached to the bottom of the seat or just loose as shown in picture. 69 manual does not cover this specific topic. Also before removal seat was hard to slide forward and back.
Re: Bench Seat Adjustment Wire [Re: LYNCHROAD69.5] #228447
02/18/09 01:49 AM
02/18/09 01:49 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Wayne;
You should have a "hook" that pulls and suspends that wire to the front of the seat, essentially removing the slack. Now you know why the seat mechanism wasn't functioning. It's probably still there, but if the hook is gone, you can easily fabricate something, just be sure it's pretty stiff, so that when you pull on the cable it will overcome the springs in the tracks and not just pull apart.
MB
Re: Bench Seat Adjustment Wire [Re: HPMike] #228448
02/18/09 05:04 PM
02/18/09 05:04 PM
Massachusetts
Massachusetts
Mike, that confirms my suspcion that something was missing....thanks. I know this is a streach but can anyone post a picture of the correct hook with location?
Re: Bench Seat Adjustment Wire [Re: LYNCHROAD69.5] #228449
02/18/09 05:13 PM
02/18/09 05:13 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
And where I can find the wire - that's what I need.
