beefing a 383-spec 727 #2281719
04/03/17 04:57 PM
04/03/17 04:57 PM
dogdays Offline OP
dogdays  Offline OP
So in another post I mentioned a newly rebuilt "motorhome" Torqueflite that turns out to be from a 2-barrel 383, making it about the least heavy-duty configuration.
This is going behind a 400-based stroker with great street manners, something that will be expected to pull a loaded 10,000lb trailer over the Rockies.
The transmission has never been run since the rebuild, it was a spare, so I was told. It also came with a brand new torque converter which judging from the size has a quite low stall speed. I will certainly use the converter and intend to use the transmission.
Let's say the transmission is from a 1968 Newport with 2-barrel 383. What will I need to change internally to be able to handle the torque? I am planning 550 lb-ft. The time to make the changes is now, because the tranny is clean.
So what needs to go? What stays? What gets added to?
Thanks,
R.
Re: beefing a 383-spec 727 [Re: dogdays] #2281723
04/03/17 05:11 PM
04/03/17 05:11 PM
Chicago
PurpleBeeper Offline
Chicago
Well, as far as I know there's only two 727 big block transmissions...Hemi & everything else, so you're 383 2bbl. trans is pretty solid in my opinion. There are a ton of "race" upgrades, but all I think you need is a transmission cooler....."maybe" a shift kit.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: beefing a 383-spec 727 [Re: dogdays] #2281751
04/03/17 06:04 PM
04/03/17 06:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Problem with any 40+ year old 727 is you never know what's inside without pulling it apart. Even though the part number might ID it as a 383-2, it might have been upgraded over the years.
Re: beefing a 383-spec 727 [Re: dogdays] #2281934
04/04/17 12:00 AM
04/04/17 12:00 AM
crlush Offline
crlush  Offline
iagree
Re: beefing a 383-spec 727 [Re: crlush] #2282319
04/04/17 04:52 PM
04/04/17 04:52 PM
dogdays Offline OP
dogdays  Offline OP
Well, PB, Chrysler built transmissions to the torque of the engine they were bolted to. Thee were three configurations for bigblocks, and the 383-2 got the one with the lowest number of clutches and planetary gearset pinions.
And JK, I doubt seriously that any modifications have been done to the transmission. But until I open it up, there's no way of telling. I've had it sitting under my workbench for 25 years. (Life got in the way.)
R.
