Re: Rear disc brake swap on Dana 60
[Re: moparmandc]
#2278241
03/29/17 11:27 AM
03/29/17 11:27 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I'm going to be doing it on my Dana 70 but haven't done it yet. I got the brackets from Great Lake Off Road. I've been waiting to get my little beater car back from my son before I undertake this project. I'll take pics and post a write up with parts used and all that when I do it.
[Re: savoy64]
#2278308
03/29/17 02:07 PM
03/29/17 02:07 PM
Posts: 10,634 Freeport IL USA
poorboy
Freeport IL USA
i would say the stopping will be the same----that kit will lose the rear emergency brakes-----there are reman? cadillac brakes that are the same size as the gm fronts with an emergency brake feature-----they were only made for about 2 years and are really hard to find at the junkyard---and i have heard there is a new source for them------and the stopping power will be about the same..... Did Cadillac brakes ever come in 8 bolt set ups? I suspect the OP won't want to loose the 8 bolt wheels on his 3/4 ton pickup. I can't believe there are no factory 8 bolt rear wheel disc brake setups out there, the rotors and e brake stuff would be the most difficult thing to locate, brackets should be pretty generic and can bolt on or weld on to the housing. Gene
[Re: poorboy]
#2278399
03/29/17 04:33 PM
03/29/17 04:33 PM
Guitar Jones
i would say the stopping will be the same----that kit will lose the rear emergency brakes-----there are reman? cadillac brakes that are the same size as the gm fronts with an emergency brake feature-----they were only made for about 2 years and are really hard to find at the junkyard---and i have heard there is a new source for them------and the stopping power will be about the same..... Did Cadillac brakes ever come in 8 bolt set ups? I suspect the OP won't want to loose the 8 bolt wheels on his 3/4 ton pickup. Gene It doesn't work that way. You use K20 front rotor hats and put them on the rear wheel hub after you press the studs out and remove the drum. The hats still mount inboard so you have to press the studs back in. Good luck doing that with a hammer and punch. It's true the calipers won't have a parking brake unless you use the Eldorado calipers. But not only are the calipers impossible to find in a junk yard the cores are expensive and most remans don't come with the levers. If you have a stick truck then you would have to use an alternative for a parking brake. Mine is an automatic and I live in Florida so I'm not worried about it.
[Re: moparmandc]
#2278404
03/29/17 04:47 PM
03/29/17 04:47 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I did the swap on a 8.75. My kit came with the drilled and slotted rotors, mounts and caddy calipers, and universal parking brake cables, too short for my application, so I had a boat shop make cables for me. The issue with the caddy calipers is you have to use the ebrake often to keep them adjusted. The kit I got was from master power brake.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: moparmandc]
#2278944
03/30/17 03:42 PM
03/30/17 03:42 PM
Guitar Jones
Mine is a manual so I was kinda looking toward the caddi calipers but they are pretty expensive. I saw on a ferd forum where a guy used a manual line lock as his parking brake. He said his hydraulic park brake worked just as good as the manual cable original. Honestly I'm not real worried about parking brake. It's been frozen up for 20 years or so and I haven't used it I'm not thinking I'll need it soon. I think the manual line lock is a good alternative and is what I will do if I need to add a parking brake later. Getting cables, levers and brackets all to work with the stock pedal operated parking brake just looks like a PITA for no gain. Plus I don't like screwing the pistons back in when it's time to change pads, just another PITA. I just found a 77 3/4 ton 4WD Cheby in a u pull it yard kind of close to me. So I'm going to go see Saturday if I can get the calipers, banjo bolts and small hardware pieces off it.
[Re: moparmandc]
#2338011
07/16/17 09:58 PM
07/16/17 09:58 PM
Posts: 2,042 colorado
savoy64
colorado
drum brakes need that 10 psi to keep the shoes out near the drum----disc brakes only need 2 psi to keep the pads next to the rotor----just having the master cylinder mounted on the firewall gives a column pressure near the 2 psi number---ditch the residual wherever it is....you could run a new line from the master cylinder to the rear brakes or make a short bypass line at the residual.....
