70 B-body Window to Track Plastic Locking Inserts #2277053
03/27/17 11:34 AM
03/27/17 11:34 AM
Chicago
PurpleBeeper Offline OP
Chicago
I've got a '70 B-body & the driver's window keeps coming off the track. Looking at the other side, I see that my driver's window "plastic push-in" that connects the glass to the track is missing a "lock pin".
I should have take a picture of the passenger side, but I will try to describe it. This picture if the driver's side. Towards the right, just above the regulator arm you can see the white plastic insert that connects the window to the track. There "should" be a plastic pin that pushes into the center hole of the insert you see that keeps all the insert's "4 fingers" spread apart & locked in place. Without that little plastic "locking pin", my driver's insert just keeps popping out.
The replacements I've seen online look just like what I have.....no "locking pin". I did see some A-body ones that look similar and have a screw running into that "lock pin hole" to keep the fingers spread. I'm half-temped to try a hardware store screw in mine.
Where can I get these window "plastic push-in" pieces that have the "plastic locking pins"? OR... what else can I do to keep my window on the track?
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 70 B-body Window to Track Plastic Locking Inserts [Re: PurpleBeeper] #2277075
03/27/17 12:00 PM
03/27/17 12:00 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I think there are a lot of sponsor companys that have what you are looking for . . . check out R/T Specialties, uh, BEA, Tony's parts, etc . . .
Re: 70 B-body Window to Track Plastic Locking Inserts [Re: PurpleBeeper] #2277076
03/27/17 12:06 PM
03/27/17 12:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
usually i would say check out Dixie Restoration's site but i can't figure it out anymore. http://www.classicindustries.com/product/mopar/parts/mn2879.html
i don't know if you can buy just the plug you are looking for
Re: 70 B-body Window to Track Plastic Locking Inserts [Re: mikemee1331] #2277088
03/27/17 12:17 PM
03/27/17 12:17 PM
Chicago
Chicago
Thanks guys, but this is what I keep seeing. Their kit doesn't include the "locking insert" I need frown
Re: 70 B-body Window to Track Plastic Locking Inserts [Re: PurpleBeeper] #2277099
03/27/17 12:29 PM
03/27/17 12:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
it's there, it's inside already with just the button top showing. it pushes though the back.
Re: 70 B-body Window to Track Plastic Locking Inserts [Re: mikemee1331] #2277118
03/27/17 12:58 PM
03/27/17 12:58 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Here: http://www.megapartsusa.com/proddetail.asp?prod=102%2DRG
For the gasket just use some roofing felt.
68 Charger R/T 440 auto
Re: 70 B-body Window to Track Plastic Locking Inserts [Re: wesgtx440] #2277124
03/27/17 01:12 PM
03/27/17 01:12 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that's the John! i couldn't find it on their site.
(i used an old inner tube for my gasket)
Re: 70 B-body Window to Track Plastic Locking Inserts [Re: wesgtx440] #2277178
03/27/17 02:59 PM
03/27/17 02:59 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Back in the day the "roofing felt" type of product we used to install these came in 3 or 4 different thicknesses.. We would then paint a petroleum product ( we used kerosene) on it after install as it would thicken as it soaked up the kerosene..
Also another product available was "cork and rubber" which was like cork gasket material...
Maybe visit an auto glass shop and get some of the correct material before you have to "redo" ( I saw LOTS of em come apart ) it..
Re: 70 B-body Window to Track Plastic Locking Inserts [Re: PurpleBeeper] #2277246
03/27/17 04:46 PM
03/27/17 04:46 PM
Chicago
Chicago
Thanks everyone for your help. Turns out the window/cradle insert I had was missing 1/2 the part and I didn't know it. I was missing the "pin" that pushes in & keeps the 4 fingers apart.
