Vacuum during a 1/4 mile run #2276521
03/26/17 02:58 PM
03/26/17 02:58 PM
NJ
cb1289 Offline OP
cb1289  Offline OP
NJ
I realize engine vacuum drops off at the hit of the throttle but does it return in any amount during the run. Just curious. Thanks.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Vacuum during a 1/4 mile run [Re: cb1289] #2276527
03/26/17 03:10 PM
03/26/17 03:10 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Depends on the size of the carb or throttle body relative to the engine's displacement.
Re: Vacuum during a 1/4 mile run [Re: cb1289] #2276565
03/26/17 03:59 PM
03/26/17 03:59 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I used to have 1" of vac going down the track with a 408 and a 850. I believe the theory is 1.5"@full throttle equals correct carb size.
Re: Vacuum during a 1/4 mile run [Re: mopar dave] #2276641
03/26/17 05:41 PM
03/26/17 05:41 PM
NJ
cb1289 Offline OP
cb1289  Offline OP
NJ
493", 2-750 eddy carbs, 12.4 cr, 275-283 roller .650, 3710 lbs.
Re: Vacuum during a 1/4 mile run [Re: cb1289] #2276647
03/26/17 06:07 PM
03/26/17 06:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you using a evac on the engine or is this
just the intake/vac number your looking for
wave
Re: Vacuum during a 1/4 mile run [Re: MR_P_BODY] #2276815
03/26/17 11:07 PM
03/26/17 11:07 PM
NJ
cb1289 Offline OP
cb1289  Offline OP
NJ
No evac. Just wondering if metering rod springs that were too light could cause the carbs to go lean on top by the vacuum possibly sucking the rods back down even slightly.
Re: Vacuum during a 1/4 mile run [Re: cb1289] #2276940
03/27/17 01:46 AM
03/27/17 01:46 AM
AndyF Online content
AndyF  Online Content
Not with dual 750 carbs. Some NHRA stock class guys have problems with high vacuum since they are forced to run small carbs. Same thing happens with the 350 cfm carb circle track guys. But with dual 750 carbs you probably are running less than 1.5 inches of vacuum at WOT.
Re: Vacuum during a 1/4 mile run [Re: cb1289] #2277003
03/27/17 09:01 AM
03/27/17 09:01 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I also run a pair of 750s.
What jets and rods are in yours?
NMCA NSS 67 Coronet
Re: Vacuum during a 1/4 mile run [Re: cb1289] #2277023
03/27/17 10:18 AM
03/27/17 10:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run a pair of 1407 Eddy 750. 572, 285/292 cam, 15-1, 6 psi fuel pressure. Summer tune is orange springs 113 primary, 110 secondary, .042" rod. Car has been 9.09@147 in summer air. Up one step (116/113) in cool air 9.04@148.
Doug
Re: Vacuum during a 1/4 mile run [Re: dvw] #2277096
03/27/17 12:24 PM
03/27/17 12:24 PM
NJ
cb1289 Offline OP
cb1289  Offline OP
NJ
Carb setup on mine is .113 pri. .107 sec, .071x.047 rods. orange springs .043 shooters middle or top hole on the lever. Floats set by the book 7/16 drop, .110 n&s. 6lb.fp. Sometimes increase the sec. jet to .110
Runs pretty nice this way. Plan on trying smaller shooters .035 this season and also would like to try different secondary boosters from a set of older afb's (3721 afb from 327 chevy 300hp)just to see how it will work. Anyone been down this road?
Thanks for the replys.
Steve
Re: Vacuum during a 1/4 mile run [Re: cb1289] #2277191
03/27/17 03:12 PM
03/27/17 03:12 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I prefer boost
