318 build #2270459
03/16/17 11:35 AM
03/16/17 11:35 AM
Indiana
Rammagnum Offline OP
Indiana
I am wanting to build up and turbo my now stock 318 Magnum, I was looking for some insight and or direction for parts to upgrade internals and suck to be able to accommodate this build. Thank you in advance
Re: 318 build [Re: Rammagnum] #2270501
03/16/17 01:01 PM
03/16/17 01:01 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
1:What is the budget?
2:What kind of horsepower are you looking for?
Re: 318 build [Re: moparborn] #2270555
03/16/17 02:32 PM
03/16/17 02:32 PM
Indiana
Indiana
Budget about 5,000 in total liking around 500 hp if possible
Re: 318 build [Re: Rammagnum] #2270765
03/16/17 08:36 PM
03/16/17 08:36 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Another question is,what is your skill level.
For durability,a bottom end upgrade is recommended,crank,rods and pistons.
The heads with a little work should be good.
Would suggest a cam to optimize the turbo.
A quality head gasket is mandatory.
A hi flo oil pump to keep things healthy and cool.
Also there will be other upgrades required,ignition,fuel delivery,carb or fi.
And a variety of fab work.
Re: 318 build [Re: Rammagnum] #2272162
03/19/17 04:30 AM
03/19/17 04:30 AM
Colorado, Way up high
Highwaystar94 Offline
I've got a 318 magnum at mine and from what I've seen you'd be better off swapping it for a 360 which is what i plan to do
'94 Dodge Ram 1500
Re: 318 build [Re: Highwaystar94] #2273819
03/21/17 06:07 PM
03/21/17 06:07 PM
dogdays Offline
dogdays  Offline
The 5.2 Mag motor should need little in the way of beefing for turbo use.
Crankshaft stock cast iron is plenty strong.
Rods are also stout, are the same as the 5.9 Mag motor which can get to 500hp naturally aspirated.
Pistons should be forged and I'd look to keep the dual squish design but with a deeper dish to drop compression from the stock 9:1. They'll cost you some dough.
Block is OK.
Hydraulic roller cam would need changing for a turbo-specific grind.
Exhaust manifolds possibly could be reused or turbo specific headers would be better
You need an intercooler
I think the stock beer barrel intake would be restrictive and would suggest either the MP single plane FI intake or maybe a converted carb intake.
Heads I'd use the EQ heads or possibly an aluminum head like the Edelbrock Mag head. Or ProMaxx or ???
I guess I'd go aluminum to cut down on detonation risk.
For a clutch I'd suggest a 12" Borg & Beck or diaphragm.
To double the horsepower you need about 15# of boost and that ain't peanuts.
I like the small engine hi pressure turbo for economy. But it's a lot easier making 500hp from a 408. Most of us don't use that much power every day, going smaller engine should let us drive more affordably, while the turbo is there for the times the grunt is needed.
R.
Re: 318 build [Re: Rammagnum] #2276899
03/27/17 12:43 AM
03/27/17 12:43 AM
Kingman, Az
Scojodak Offline
Scojodak  Offline
Kingman, Az
Don't overlook a tranny upgrade of about $1500/$2000
Dakota for life!
