71-74 b-body will column swap #227645
02/17/09 09:59 AM
02/17/09 09:59 AM
Fla
birdboy Offline OP
birdboy  Offline OP
Fla
wondering if a p/s floor shift 74 b-body will fit in a 71 with p/s floor shift? will the turn sig switch and ign plug in or will you have to splice them? thanks for your reply.
Re: 71-74 b-body will column swap [Re: birdboy] #227646
02/17/09 10:01 AM
02/17/09 10:01 AM
a cornfield near you
BlakDak Offline
BlakDak  Offline
I doubt it will even bolt in, as the 73 and later K frame is rubber isolated.
I forget when they did the change on the bracket that bolts to the floor, but there is a difference in them also.
Re: 71-74 b-body will column swap [Re: BlakDak] #227647
02/17/09 10:05 AM
02/17/09 10:05 AM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
No 71 and 72 will interchange but 73-74 are different because of the different K-frame design
Re: 71-74 b-body will column swap [Re: birdboy] #227648
02/17/09 11:58 AM
02/17/09 11:58 AM
IL
71383beep Offline
71383beep  Offline
IL
You can make it work. The shaft and steering coupler are different. The 73's and 4's came with a rag joint that will not work with headers. It's not hard to swap the shafts. The column,wiring, and mechanicals are very similar though.
When i bought my car it had a 73 column in it from the guy who was working on it originally.
I ended up cobbling a decent column together from 3 other columns.
'73 GK6 Challenger Rallye - 340 4-Speed
