Bleeding Brakes on a body #2276178
03/25/17 09:29 PM
03/25/17 09:29 PM
England
fastfish451 Offline OP
England
have discs all round with mopar after market master cylinder
when I bleed the front pedal goes to floor
when I bleed the rear pedal goes about 3/4 is this correct??
Re: Bleeding Brakes on a body [Re: fastfish451] #2276180
03/25/17 09:39 PM
03/25/17 09:39 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
While bleeding, or after you're done?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Bleeding Brakes on a body [Re: amxautox] #2276182
03/25/17 09:44 PM
03/25/17 09:44 PM
England
England
while bleeding is this right
Re: Bleeding Brakes on a body [Re: fastfish451] #2276183
03/25/17 09:45 PM
03/25/17 09:45 PM
Sterling Conn
manymopars Offline
manymopars  Offline
Sterling Conn
What make and model are you working on and what method are you using to bleed the system.
Re: Bleeding Brakes on a body [Re: manymopars] #2276184
03/25/17 09:49 PM
03/25/17 09:49 PM
England
England
67 barracuda
pedal down open bleed
close bleed pedal up
Re: Bleeding Brakes on a body [Re: fastfish451] #2276185
03/25/17 09:51 PM
03/25/17 09:51 PM
first I would put a block of wood under the pedal to limit its travel to the normal range (not a dealbreaker but it keeps the cups in their normal worn range of travel in the bore). not sure why the rear bleeding wont go down, I would try it on both of the rear bleeders (which you have likely already did) & if no change then possibly crack the T hose fitting back there & repeat. are you running a prop valve of any kind?
Re: Bleeding Brakes on a body [Re: fastfish451] #2276190
03/25/17 09:58 PM
03/25/17 09:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
he has 4 wheel DISCS
So not stock.
And what is "mopar after market master cylinder"?
Who knows what you have so who's to say how it should act.
Some details would be nice
Don't be the exception.
Re: Bleeding Brakes on a body [Re: RapidRobert] #2276191
03/25/17 10:00 PM
03/25/17 10:00 PM
England
England
yes I am running a stock brass proportioning valve have been running this system for some time just changed some brake lines and really struggling to bleed them just cant remember if pedal was doing this before.
mopar performance m cylinder
Re: Bleeding Brakes on a body [Re: fastfish451] #2276198
03/25/17 10:12 PM
03/25/17 10:12 PM
the cups I am referring to are the MC cups. on a MC with some miles I like to keep those cups in that normal worn area when bleeding (not a dealbreaker but does extend the life of the piston seals). I would crack the line just upstream from the prop valve see what develops. does this valve have the pin that you pull out to bypass the proportioning? EDIT & a block of wood gives your helper more control over the pedal movement & on discs I like to have him pump it several times then with good verbal timing I open the bleeder on his last downstroke as this agitation gets the air out better but we ain't there yet, first we gotta find out what is going on.
Re: Bleeding Brakes on a body [Re: fastfish451] #2276224
03/25/17 11:08 PM
03/25/17 11:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Last thing I would run is a stock combination valve on an all disc setup.
Re: Bleeding Brakes on a body [Re: Supercuda] #2276635
03/26/17 05:33 PM
03/26/17 05:33 PM
England
England
hey Supercuda thanks for info can you tell me how you would run this system cheers
Re: Bleeding Brakes on a body [Re: fastfish451] #2276698
03/26/17 07:38 PM
03/26/17 07:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not without a lot more info than you've given.
Since no A body came with 4 wheel discs stock I cannot begin to guess what you have or what you may or may not need. Other than not needing a stock combination valve in an all disc system
Re: Bleeding Brakes on a body [Re: Supercuda] #2276747
03/26/17 09:23 PM
03/26/17 09:23 PM
I would bypass the prop valve & see if it bleeds out (I think it will) then take it out for a spin & see how the proportioning feels.
Re: Bleeding Brakes on a body [Re: RapidRobert] #2277070
03/27/17 11:55 AM
03/27/17 11:55 AM
England
England
ok here we go
I have strange ss struts on the front with 4 piston calipers.
On the rear I have strange single piston calipers
I am using the brass splitter box I think this is stock, not sure if this is a proportioning valve ?
spent some time bleeding these pedal still feels a bit spongey
thanks
Re: Bleeding Brakes on a body [Re: fastfish451] #2277104
03/27/17 12:42 PM
03/27/17 12:42 PM
sppongy is air. I would bleed the MC first
Re: Bleeding Brakes on a body [Re: RapidRobert] #2277216
03/27/17 04:04 PM
03/27/17 04:04 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
On a good 4 wheel disc system Master Cylinder bore and caliper piston diameter come into play for optimal performance. You would be better to not use a proportioning valve and simply plumb in an adjustable one on the rear brakes. If you simply swapped out hoses to new from what you had before it sounds like there is still air trapped somewhere... twocents
FWIW sometimes I open the bleeder and then have someone depress the pedal and then close the bleeder during the first attempt at bleeding. Kind of what Robert touched on earlier...
...FAFO...
