what is this engine fan? #2275462
03/24/17 05:01 PM
03/24/17 05:01 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I have a seven blade clutch style Mopar fan with the numbers A83 then below the patent pending number is 140 15566. It looks to be about 18 1/2 to 19 inches. Any ideas what this engine this would fit. I am working on a 70 440. thanks for any ideas.
Re: what is this engine fan? [Re: gregok] #2275775
03/25/17 02:50 AM
03/25/17 02:50 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Are the blades steel or aluminum?
Re: what is this engine fan? [Re: gregok] #2275860
03/25/17 10:56 AM
03/25/17 10:56 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Pictures?
Does it mount to a clutch or a spacer?
What's the gear ratio of your car?
Does it have AC?
Re: what is this engine fan? [Re: NANKET] #2276034
03/25/17 03:46 PM
03/25/17 03:46 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Blades are steel.
Re: what is this engine fan? [Re: Morty426] #2276036
03/25/17 03:50 PM
03/25/17 03:50 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
No pics, gear ratio3.55 non air car, clutch mounted.
Re: what is this engine fan? [Re: gregok] #2276202
03/25/17 10:17 PM
03/25/17 10:17 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Then your fan should have the part number stamped in the blade 2806216
